will trd pro suspension and shock raise my truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John Ka, Oct 8, 2015.
  1. Oct 8, 2015 at 12:29 PM
    John Ka
    John Ka [OP] Member
    2015 black tacoma
    exhaust air filters wheels and tires
  2. Oct 8, 2015 at 12:32 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    yes it will raise your truck, if current wheels fit they will fit after lift, suspension doesn't void the warranty. They now have to prove that the mods you did to your truck caused the problem.
    I would go with a after market suspension, I got a full fox suspension for around the same price!
  3. Oct 8, 2015 at 12:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It will raise your front end approx. 2", it does not raise the rear. The 3 leaf progressive AAL is a popular choice for a small rear lift with a good ride without spending too much if you want to lift the rear too. Baja has a 650lb spring rate, Pro has a 600lb spring rate. I have a link in my sig with the before and after install of the Baja Pro.
    TRD Pro suspension: http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-10412
    TRD Baja TX Pro suspension: http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-10512
    Icon 3 leaf progressive AAL: http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8788
