Will trd rear axle fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by madseacow, Jan 9, 2012.
  1. Jan 9, 2012 at 6:38 AM
    madseacow
    madseacow [OP] Member
    Austin
    98 SR5
    I know I'll probably get flamed, but my searching is sucking and I need info quick. I found a 2001 trd at the local junk yard with a killer price on the rear axle, can I swap it into my 98 4wd without major drive train mods? I know getting the locker to function takes work, but is this deal worth jumping on?
  2. Jan 9, 2012 at 6:53 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If its a good enough deal, go for it.
    Its possible to make anything fit. Not sure how far off it'll be.
  3. Jan 9, 2012 at 8:34 AM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    It's still a 1st gen axle so I don't see much difference. But that's just my opinion. Pretty sure someone with more info will chime in. Nice find see if you can find the truck it came off of and take the e-locker wiring, or as much as you can.
  4. Jan 9, 2012 at 9:55 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Same ratio as front axle, then there is the wireing issue to engage and dis engage it, might involve the computer also.
  5. Jan 9, 2012 at 10:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    Should bolt up but as Tom said, the axle codes need to be the same. I'm not sure whats different in those sub generations, but you could grab the 4x4 ecu, harness and switch to make it easier. Or do as Whipper said.
  6. Jan 9, 2012 at 11:37 AM
    madseacow
    Austin
    98 SR5
    Where do I find the axle code?
  7. Jan 9, 2012 at 11:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Driverside door jamb. Note the one on your truck may look slightly different
    See at the bottom where it says "A/TM A01A/W55"
    A = axle
    TM = transmission
    A01A = axle code
    W55 = transmission number.
  8. Jan 10, 2012 at 12:13 PM
    madseacow
    Austin
    98 SR5
    Mine's b06a, the trd is b03a. Will it work?
  9. Jan 10, 2012 at 12:28 PM
    madseacow
    Austin
    98 SR5
    Damn, thanks for all the help
  10. Feb 5, 2012 at 12:25 AM
    SchmitzM1
    SchmitzM1 Project: Shaniqua-Rise of the Purple Taco
    Michael
    Ventura
    '96 5Lug 2.4 5M/T
    Detroit Trutrac rear LSD, K&N Drop In, Deck Plate, Optima Yellowtop, Kenwood Excelon Receiver, Kenwood Excelon mids and tweeters, JL Audio 10" W2 boxed sub behind bench seat, MPL Jackhammer 800w amp, 30%window tints driver and passenger, double layer limo tint across back, double layer limo sun stripe across top 5" of windshield, Custom duct tape seat repair lol,
    Bring on the flaming, but ive been searching the threads and this is the closest one i could find without asking my similar question in a new thread...
    Will 1st gen locking axles directly swap into a 96 5lug?
    I know the hubs would be different in the front, but its 2wd and i dont care. I've been bouncing all around manufacturer sites, toyota dealers, and multiple other forums with no solid advice. Has anyone on this forum done a 5lug non locking to 6lug locking swap? if so... build thread link? Thanks
    ~Mike
  11. Feb 17, 2012 at 12:26 PM
    cdub2002
    cdub2002 Active Member
    Gresham-Corvallis Oregon
    White 2002 Tacoma SR5 trying to be TRD worthy
    Bullet Grill, Hella 500ffs, 3" suspension lift, 33" goodyear wranglers, Flowmaster 40 series, Cobra CB, debadged, Kenwood cd, infinity sound, 12" sub. husky tool box...
    Glad I found this! I have axle cod B06A, which gives me hope that I could find a TRD locking axle at a junk yard to save some money. And then I wouldn't need to regear. I never knew any of this information till I read this. Super helpful, thanks Whipper
