Will TRD shocks from a 2016 fit a 2009?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 30338, Aug 3, 2016.
  1. Aug 3, 2016 at 7:50 AM
    30338 [OP] New Member
    Guys, I've called 3 dealers with this question and can't get a definitive answer. Have some TRD shocks and coil springs from a 2016 truck that I can pick up. Just wondering if they are a bolt on option for the 2009 Tacoma or if they won't fit? Have gone through pages on the forums and some classifieds in the 3rd generation section seem to say they will fit. Just want to be sure before I jump. Any help appreciated. Thank you
    t1m829 and moe2o4 like this.
  2. Aug 3, 2016 at 7:58 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    they will bolt up without issue, but do note the 2016 springs will give you ~ an inch of lift over the 2nd gen springs.
    nermel, ChadsPride and moe2o4 like this.
  3. Aug 3, 2016 at 11:46 AM
    Thank you sir. Going to give them a shot based on that.
    ChadsPride and Hairy Taco like this.
  4. Aug 3, 2016 at 12:14 PM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    Let us know!
    ChadsPride likes this.
  5. Aug 3, 2016 at 12:15 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    ^^He is correct the 2016 suspension will fit any 2005-15 truck, and it will give you 1 Inch of lift in the front!
  6. Aug 3, 2016 at 12:18 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Please post up a post install pic OP. I am sure many would be curious to see the result
  7. Aug 3, 2016 at 12:21 PM
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    If you need a set (front coilovers, rear shocks and UCAs off a 2016 with only 1400 miles on it) let me know. I have a whole set for sale.
  8. Aug 3, 2016 at 4:09 PM
    Thanks all. Scott, supposed to pick these up on Friday afternoon. If for any reason it doesn't work out, will give you a shout. I live in Elizabeth. We'll measure before and after and will take some pics. Should be a nice upgrade for the 2009. Thanks again to all who chimed in.
  9. Aug 4, 2016 at 8:54 AM
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Bump. Found a set locally and looking for pics.
  10. Aug 4, 2016 at 9:17 AM
    nermel
    nermel New Member
    Patrick
    Hey guys - new here, have a similar question. Just picked up an 07 TRD Sport double cab LB, and am wanting to do a couple things. Previous owner put new springs (~3in lift) on the front, and it has recently restored to OME/stock leaf springs (dealer replaced before sale due to recall). So, its got a 3" lift up front, with nothing in the back. Definitely looks like it's leaning back...
    It rides pretty poorly, no doubt due to the suspension being mismatched, but also has 285-70-R18 tires and wheels, which according to my mechanic isn't helping...
    I'm going to be using it mostly on pavement, with occasional foray's off road to access camping, climbing and fishing spots... 4WD will mostly be used on snow en route to skiing. So I think the stock TRD Sport/OffRoad suspension will be plenty.
    I can score take-off OME ('15 or '16) wheels and tires on craigslist for pretty cheap, and I'll swap those out. Anyone see any issue with something like this going on my 07? Here's a pic:
    And I can also get ahold of front suspension take-offs. Would a TRD Offroad Bilstein Suspension fit my 07? (Sounds like the answer is yes, will just give it an extra 1"). And a pic of these:
    Any issue with having 1" of lift in the front from said suspension, but being factory/no lift on the rear? Am I thinking straight here?
    Thanks for the thoughts Taco Gurus!!!
  11. Aug 5, 2016 at 4:49 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I have a set of 2016's I'll get installed on the truck in about two weeks. Got sidetracked with new wheels. YES they will fit. YES they will give you an inch up front. Only think I've heard that's negative is a possible squeaking sound from the rear under load.
    SpeedwayTaco160 and nermel like this.
  12. Aug 5, 2016 at 2:55 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    Thanks, Ill be looking for the pics
  13. Aug 5, 2016 at 4:35 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    2016 struts on a 2012.
  14. Sep 13, 2016 at 9:39 PM
    aaronb43
    aaronb43 Well-Known Member
    Edmonton AB Canada
    07 SR5
    I have a 2007 SR5. Can I reuse my old coils and combine them with the struts from a 2016 TRD?
  15. Sep 13, 2016 at 9:45 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Yes
    bigfoote13 likes this.
  16. Sep 18, 2017 at 11:34 AM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Can I reuse my 2016 OEM Off Road shocks on my 2004 Tacoma?
  17. Sep 18, 2017 at 12:26 PM
    nd4spdbh
    SoCal
    No. 1st gen tacoma front suspension is entirely different.
    gargamel05[QUOTED] likes this.
  18. Sep 18, 2017 at 4:09 PM
    gargamel05
    Thank you.
  19. Sep 19, 2017 at 6:38 AM
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I wound up not using the set from the 2016. I'll post them up for sale. It's the front and rear TRD OR Suspension with about 5,000 miles on it. I'd do $150 on them.
  20. Nov 30, 2017 at 9:40 AM
    hrvrdh
    hrvrdh Member
    2005 Tacoma TRD DCLB
    3" Procomp lift
    Hi guys, I'm new here to the forums so be gentle..it's my first time. lol
    I have a 2005 Tacoma DCLB. Currently with a 3" Procomp lift(shocks,struts,coils,aal) with stock tires. I was planning on getting 33's installed but I moved in to a condo and I've already hit the top of the parkade gate with my ladder laid down on my rack.lol I clear the gate without the ladder.
    So, I've bought a set of 2016 trd suspension parts and I was going to install it after reading this forum a few weeks back. However, I'm also installing an ARB deluxe bumper and winch. My question is...will the added weight of the ARB and winch be too heavy for the 2016 trd front suspension? I've read that it will give the truck a 1" lift but will that compensate for the weight and sag of said ARB and winch? Thanks
