Will Tundra brakes work on 16" FJ TRD Trail wheels?
Discussion in 'Wheels & Tires' started by Ford2YotaGuy, Mar 11, 2019.
  1. Mar 11, 2019 at 3:27 PM
    Ford2YotaGuy
    Ford2YotaGuy [OP] Well-Known Member
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    Just like the post says will the tundra brake upgrade fit for 16" FJ TRD Trail Wheels?
    Pic of reference
  2. Jan 20, 2022 at 8:27 AM
    GyvesHD
    GyvesHD Well-Known Member
    Edgar
    2000 Toyota Tacoma SR5 4X4
    Looking to get the same rims. Do they end up clearing? Or if anyone knows if it’ll work
  3. Jan 20, 2022 at 8:30 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The 199's will, the 231's probably will not.
    GyvesHD likes this.
  4. Jan 20, 2022 at 8:31 AM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Jan 20, 2022 at 9:28 AM
    Ford2YotaGuy
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    Yes, they did fit! I should also mention I had some 1.25" Spidertrax wheel spacers on the wheels so i'm not sure if that changed anything but figured i'd mention it!
    GyvesHD[QUOTED] likes this.
  6. Jan 20, 2022 at 9:35 AM
    JCTacoma330
    JCTacoma330 Well-Known Member
    Justin
    2019 Black Tacoma DCSB OR MT
    None
    Cool information thanks for sharing!
    Could you please list for reference the part numbers of the wheels and the brake components you ordered for this to all work? I would be interested in doing something similar in the near future and that information would be super helpful.
    Thanks is possible
    GyvesHD likes this.
  7. Jan 20, 2022 at 9:42 AM
    Ford2YotaGuy
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    I gotta be honest with you, I haven't had that truck for years and don't really remember any of the part numbers or anything like that. But I can tell you that the wheels I had were OEM Toyota FJ Trail Team wheels that originally came on the FJ Cruiser. If I remember correctly, for the brakes I think I just went on Rock Auto and bought a whole brake package that was made for a 2004 Toyota Tundra. I think it was PowerStop brand and came with rotors, pads, and calipers. About $450 for everything. All bolted on perfectly except for having to trip the brake dust shield a little bit. Hopefully that helps!
    GyvesHD and JCTacoma330[QUOTED] like this.
