Will Tundra coils fit the Tacoma?
Discussion in 'Suspension' started by sportsterchop200, Dec 7, 2011.
  1. Dec 7, 2011 at 11:45 PM
    sportsterchop200
    sportsterchop200 [OP] Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    I have read that coils from a Tundra are interchangeable with the Tacoma. Is this true? I am looking to add a small lift to my truck 1.5-2". I want to run 265/75-16. Also, are the rear springs interchangable? My truck is an 03 extra cab 4x4 with the TRD package. My other consideration is for the OME 880 or 881 front coils. I am looking for the cheepest way to get a small lift and level the truck. There is currently about a 1" difference between the rear and front. Thanks in advance for any information.
  2. Dec 8, 2011 at 3:13 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Pretty sure 1st gen Tundra coils will work with 1st gen Tacomas but unless you go spacer or body lift you'll need to change your front struts to something longer , you'd probably destroy the stockers
  3. Dec 8, 2011 at 9:49 AM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    Yeah I'm planning to replace the shocks whenever I change the springs out. My truck has 85K on it. However, it came from Ohio and the underside has a lot of corrosion that needs to be cleaned up. My idea was to put the 5100's on it with a clean set of Tundra coils and leafs. I am looking to gain lift from the springs not the struts. Any additional information is appreciated.
  4. Dec 8, 2011 at 11:10 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Yeah Tundra coils will work with your Tacoma. I have them on my 4runner with Tundra 5100's. The ride is great and it's nice to have the adjustability. Just set the 5100's at the lowest setting and the coils will give you ~2" lift. You have to make sure you get Tundra TRD 4wd coils. They will have a two yellow dots on one and a yellow and blue dot on the other.
  5. Dec 8, 2011 at 12:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Exactly why you need upgraded struts to accomodate longer coils...
    For the record I'm running adjustable 5100's for a 1st gen Tundra (5 settings instead of the usual 3)
    For the rear I'd add a couple leafs (no AAL) from a Ford or Chevy, it'll give you up to 3" in rear
  6. Dec 8, 2011 at 12:59 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ya know they(toyota)will bye it back if the frame is too rusty.
  7. Dec 8, 2011 at 1:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    this is true , I forgot to mention that
    Check into it OP, schedule a frame check if possible...;)
  8. Dec 8, 2011 at 1:53 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    I read about the buy back program somewhere. I even contacted Toyota. I was informed that my vin and year was not elligable for the recall.
  9. Dec 8, 2011 at 2:19 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    oh wow..........thats the first i heard that on the first gens.
  10. Dec 8, 2011 at 6:21 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    Yeah, I was told that the recall only goes up to the year 2000, I have a 2003. However from what I have seen I am pretty sure that I can clean it up with a wire brush and some paint or undercoat. However, in regards to the lift I should look for a 00-06 Tundra TRD 4x4 for the coils.
  11. Dec 8, 2011 at 8:14 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    Yeah 00-06 Tundra TRD 4x4 coils and most likely from a access cab. They are bit tough to find, but you should be able to get them for around $75-150.
  12. May 10, 2016 at 8:23 PM
    jeepsneedheros2
    jeepsneedheros2 New Member
    declan
    03 trd taco
    what year tundra coils will fit 2003 taco?
  13. May 10, 2016 at 8:56 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2000-2006 trd coils.
