Will tundra crewmax JL stealthbox fit behind the seat of a doublecab Tacoma??
Discussion in 'Audio & Video' started by OoRrLlYy, Jun 8, 2012.
  1. Jun 8, 2012 at 12:22 AM
    OoRrLlYy
    OoRrLlYy [OP] Member
    Kalihi/Oahu/Hawaii
    '12 TRD sport DCLB 4x4
    I wanna put a stealthbox out of a Tundra crewmax in my doublecab Tacoma! Will it fit? Has anyone tried this? I want to upgrade my sound system but would rather have a 13tw5 than two 10w1 subs.
  2. Jun 8, 2012 at 7:37 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Why don't you just use a subwoofer enclosure DESIGNED for the Double Cab Tacoma with a 13TW5 in your truck? Would that make too much sense? I know Marv makes them.
  3. Jun 8, 2012 at 7:47 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I'm doubtful because the tundy box goes under the seat firing back and has a little lip by the sub the contours to the back if the seat in the tundy. Either making your box per a prefab will be fine. Jl makes a stealth box for the tacoma if you don't want that check out supercrewsound.com they make a box that will fit 1, 2, or 3 JL W3's.
  4. Jun 8, 2012 at 7:49 AM
    qualitysound
    qualitysound Active Member
    Paul
    Abilene, TX
    ^^^Truth, but to answer your question, no, it won't fit. The back walls are very different.
  5. Jun 8, 2012 at 7:58 AM
    qualitysound
    Paul
    Abilene, TX
    The doublecab box goes under the seat. The crewmax goes behind the seat.
  6. Jun 8, 2012 at 10:48 AM
    OoRrLlYy
    Kalihi/Oahu/Hawaii
    Well yes I've thought of that but the reason I'm asking is because I would rather have the 13tw5 vs two-10w1 and I can get the tundra box locally
    Actually the crewmax stealthbox mounts behind the seat
    Yes the back walls are different but I don't need it to fit flush like its supposed to be there, I just wanted to know if they'll fit period
  7. Jun 9, 2012 at 6:54 AM
    qualitysound
    Paul
    Abilene, TX
    You'd have to find one locally or contact JL. The Tundra has more room behind the seat but those are the only ways to know for sure.
    I'd just build one or have one built.
