Will URD MAF sensor calibrator Help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Geno96542, May 6, 2011.
  1. May 6, 2011 at 5:30 AM
    Geno96542
    Geno96542 [OP] New Member
    Gene
    Charleston SC
    2010 Tacoma 4x4
    K&N CAI Borla catback exhaust
    Hello
    Just a quick question. I have a 2010 tacoma crew cab 4x4 with K&N CAI and Borla exhaust. Just wanted to know if I should get a URD MAF sensor calibrator and how much it will cost to get it tuned or buy the tools to do it myself.
    Thanks
  2. May 6, 2011 at 8:08 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ditch the K&N filter for an AFE pro dry S drop in filter. you are drawing in hot air from the engine with that K&N.
    Call up URD and see if they can map the MAF CAL for the mods you have done for you before they send it out. otherwise it can be hard to find anyone that can tune them
  3. May 7, 2011 at 9:25 PM
    Geno96542
    Gene
    Charleston SC
    2010 Tacoma 4x4
    Thanks for the help.
  4. May 28, 2011 at 6:25 PM
    eeberleeber
    eeberleeber Well-Known Member
    northeast CT
    05 2.7l 4x4 stock
    URD short throw shifter, Bilstein 5100's front and rear, Nitto TG 265/75
    I've got a k&n intake and an lce header on my 2.7l, both added prior to the urd maf calibrator. The urd maf calibrator was the single most noticable difference in performance. (Of course it's tuned based on the k&n intake.) I installed it, took it out for a test spin, and was grinning ear to ear!
    My point is: I would *highly* recommend coupling the maf calibrator with the k&n intake. My truck definitely has increased pick up through moderate rpms in 1st-4th gears with the urd.
    My conclusion is that the stock ECU cannot tune itself to take full advantage of the performance intakes. I did notice modest performance gains with the k&n alone, but with the urd maf calibrator it's like night & day.
    Install wasn't bad either. If you can solder a harness for an aftermarket stereo, you can definitely do the urd maf install.
