Will Wheels From Gen 1 fit Gen 2 Tacoma?
Discussion in 'Wheels & Tires' started by Benny, Nov 12, 2017.
  1. Nov 12, 2017 at 7:51 PM
    Benny
    Benny [OP] Well-Known Member
    2008 DC LB more mods by the month
    I’ve got an 08 that I only use for hunting and fishing. My friend has the wheels from an 02 with great tires on them. His are 16” and because mine is TRD Sport I’ve got 17” rims. Can I just bolt those 16” rims on my 08 or will there be backspacing problem?
  2. Nov 14, 2017 at 5:33 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If his is a prerunner or 4x4 the bolt pattern will work but I believe the backspacing is pretty different between the gen1 vs gen2. You might consider buying the set for the tires and picking up some cheap second hand TRD OR wheels for a 2nd gen, you are going to need to swap the TPMs over anywhay requiring the tires to be removed from the wheels unless you want the low tire warning on all the time.
  3. Nov 15, 2017 at 10:17 AM
    #4TOY4ME
    #4TOY4ME Now driving #5
    Robert
    Kingman AZ
    17 MGM OR 4X4 AC
    Level 8 Mk6 16x8 0 offset , Bilstein 5100 G4 Elite Fold A Cover
    Best way to find out is to test fit them on your truck. A tape measure will let you know the backspacing. There is a good chance they will fit just fine. Give it a try.
    Robert
