Win a prize by answering these simple skill testing questions!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Mar 26, 2010.
  1. Mar 26, 2010 at 10:35 PM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    ok, I looked...glanced... through the 9 million pages of the owners manual and can't seem to find an answer for these...
    1) What the hell does the RSCA button do????? My best guess is Rear Stability Control Action
    2)What does the "Set" button (next to the hood release) do?? I thought it was adjustable pedals but nope.
    3) How do I get the FRONT cab lights to turn on when I open the door (currently only the back cab lights turn on)??
    4) If I push the front cab light on and then forget to turn it off when I exit the truck, will it automatically turn off??
    Prize awarded to first person who correctly answers all questions.
  2. Mar 26, 2010 at 10:38 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    The set button is for reseting the TPMS (Tire Pressure Monitoring System).
    As for any of the interior lights, if you forget to turn them off, they will eventually go off on there own. They are on a timed circuit to prevent dead batteries.
    Cant help you on the other two questions as my truck doesn't have an RSCA button, and I'm not sure how you would get the map lights to turn on when you open the door.
  3. Mar 26, 2010 at 10:40 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    1) The first one is kind of important. Roll Sensing Curtain Bags. Turn it off and on. At least, thats what I was made believe...
    2) The second button is used to reset your TPMS
    3) For your lights, put the tab on the back light to door. If that doesnt work, then your truck wont use that setup unless you mod it yourself.
    4) Mine does not turn off automatically. Later models do, I was just told.
  4. Mar 26, 2010 at 10:41 PM
    SC4333
    Grant
    San Antonio, TX
    I just remembered, the RSCA button disables the side curtain airbags for when you're feeling froggy off road. I think the last thing you would want while doing a little bit of four wheeling would be to have the air bags deploy on you. :eek:
  5. Mar 26, 2010 at 10:43 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Answers:
    1) The RSCA controls the Roll Sensing Curtain Airbags which would be deployed during a roll over incident. Press and hold the button to turn it off.
    2) The set button resets your TPS senors. Press and hold it to reset.
    3) YOu can't unless you mod it. It's stupid. The front lights are MAP lights.
    4) No they will stay on untill you turn them off manually.
    I spent ten minutes on this, thats $20.
  6. Mar 26, 2010 at 10:54 PM
    MikeDeason
    Thanks.... but EVERY other truck I've owned had the front cab lights turn on when you open the door...kinda makes it easier to see in the dark....How the hell is that stupid?
  7. Mar 26, 2010 at 11:02 PM
    I Liquid I
    Puerto Rico
    There is probably a way to wire the front inner lights to the center lights and use the door light switch in that way. As to how, I wouldn't really know, but im sure someone who knows anything about wiring can chip in on that one.
  8. Mar 26, 2010 at 11:03 PM
    SC4333
    Grant
    San Antonio, TX
    I'm pretty sure he was referring to the fact that the truck must be modified in order to have the map lights illuminate when the doors are opened. And FWIW the map lights WILL turn off after, maybe 20 or 30 minutes, if left on. I've had this happen to me a couple times while I was filling out paper work in my truck with the map lights on, and the door shut. The lights would simply turn off after a certain period of time.
  9. Mar 26, 2010 at 11:09 PM
    MikeDeason
    ok thanks...personally I think the front cab lights should just turn on when you open the door without a mod.....seems pretty logical...never seen a truck that doesn't have this.
    I'm glad they turn off automatically cause I tend to forget to turn them off....my Titan kept them on for 1 minute after turning the truck off...that was a nice feature.
    How the hell do you know if they are disabled or enabled??????
    There doesn't seem to be any indicator light anywhere....where is it???
    THANKS!!!!!!!!!!!!!!!!
  10. Mar 26, 2010 at 11:17 PM
    SC4333
    Grant
    San Antonio, TX
    I couldn't tell you to be honest. My truck does not have the side airbags.
    Use the websites search feature and you can find out all the answers you want about the RSCA button.
  11. Mar 27, 2010 at 6:00 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I'm pretty certain there's a light in the instrument cluster to tell you when RSCA are switched off.
  12. Mar 27, 2010 at 6:10 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Must be an addition to the newer models. My map lights have drained my battery at least twice after I mistakenly left them on.
  13. Mar 27, 2010 at 6:14 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    theres a light in your instrument cluster that will say "rsca off"
  14. Mar 27, 2010 at 11:56 AM
    bigmooze
    Richard
    Belle River, ON
    Yup, and remember to hold the button in to turn them off, and hold again to turn them back on
  15. Mar 27, 2010 at 12:30 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Just checked my truck for the map lights and the RSCA. The book says that the lights are manual. They need to be turned on and off, won't do it automatically. As far as the RSCA, this is what the book says and where the RSCA light is located.
  16. Mar 27, 2010 at 1:51 PM
    SoCalR
    SoCalR Well-Known Member
    Rand
    San Diego, CA
    05 TRD Sport PreRunner
  17. Mar 27, 2010 at 2:07 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    the map lights do turn on with the dome light if you set the setting to door on the dome light :S. at least they do in my 07 5 lug base.
    i know this because i have mistakenly had the door open and clicked the map light, when i closed the door the one i clicked stayed on. and also they do turn off automatically if left on
  18. Mar 27, 2010 at 8:19 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    And remember to read far enough into the post because you DO NOT need the diode. Just a simple wire from the map lights to the dome light and switching the wires in the plug at the map lights. That's it. Best mod out there since it is stupid for Toyota not to have done this from the start!
  19. Mar 27, 2010 at 11:06 PM
    MikeDeason
    Will try this Tomorrow...THANKS!
    Apparently you have to HOLD the button for a few secons which I didn't do...will try this tomorrow...I just pressed the button....Thanks!
    One other minor thing....It would be nice if the back up cam image had 2 laser lines which indicated the area in the trucks path....my F150 had this and it was SWEET....
  20. Mar 27, 2010 at 11:30 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    so who won the prize
