Winch control module locations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlessdApparel1, Dec 30, 2020.
  1. Dec 30, 2020 at 5:40 PM
    BlessdApparel1
    BlessdApparel1 [OP] Overland Warehouse Online
    Oceanside
    2013 Tacoma Build In Progress
    @pelfreybuilt Aluminum Front Bumper @Dirtking 2.5 Long Travel @bajadesignsofficial Fog Pocket Kit, S1’s, A Pillar Squadrons @bajadesignsofficial 20” S 8 @cbioffroadfab Bedrails @mountain_hatch Tailgate Attachment @dirtylyfewheels 17” Roadkill Race Beadlocks @falkentire Wildpeak A/T’s @yakimaracks RTT @nickdeyatnight Rocksliders And Custom Rear Swingout Bumper @shibui_tank On Board Air @calicowboywhiskey Whiskey @phalcon_trailers Dualzone Fridge @fabzonearmor Skids @Allpro Offroad Bed Stiffners And Gas Tank Skid @archivegarage Rear shock location @Iconvehicledynamics RXT Leafs Pack @4xinnovations hangars and shackle flip @Radflo Custom 2.0 resis with finned 2.5 Res and adjuster
    Hey Guys,
    I just go finished installing a new Warn 12.5 K winch on the truck.
    the winch itself fits in the bumper but i can’t get the front supports of the truck back on without relocating the control module. What have you guys done to relocate and where have you placed them?
  2. Dec 30, 2020 at 5:49 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    This is what we came up with for mine.
    deanosaurus likes this.
  3. Dec 30, 2020 at 6:02 PM
    BlessdApparel1
    Oceanside
    That’s an interesting setup for sure. My bumper and skids i don’t think would allow that
    llamasmurf[QUOTED] likes this.
  4. Dec 30, 2020 at 6:05 PM
    llamasmurf
    Wes
    Northern Ontario
    Yea everyone's setup is different. Just figured id toss up the idea we landed on. Maybe you can mod it and use it, maybe you cant.
    :thumbsup:
  5. Dec 30, 2020 at 11:28 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Place up the engine bay to keep out of the elements. Extend the winches wires to make it fit where you want.
    here’s where I put mine. Been working great for almost 9 years.
    48AF9F14-1DFD-461F-9E83-882556F3FBA8.jpg BDEC7809-B3B8-40A9-8232-3E8E8B3D7A57.jpg
  6. Dec 31, 2020 at 3:20 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Do you have to keep your hood open to use the winch controller or do you have a switch mounted in the cab?
  7. Dec 31, 2020 at 3:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Added square aluminum tube. Moved my box up off the winch, mostly out of splash zone. Didn’t extend supplied wire.
  8. Dec 31, 2020 at 3:53 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
  9. Dec 31, 2020 at 5:44 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    negative. I hardwired a switch into the cab.
    But if I get into a spot where I need to use a remote warn has a wireless controller, which of course uses a battery so I do carry the hardwired controller as a backup in which case I’d need to open up the hood.
  10. Dec 31, 2020 at 7:54 AM
    BlessdApparel1
    Oceanside
    Thank all of you for the input
    i like what I am seeing.
    What did you guys use for brackets in these locations, if possible Idk if I want to run to under the hood because it seems like a PITA to do all that when i need to pull myself or someone out, but I’m considering it.
    I’m trying to figure out a mount or something for both of these locations and I’m not sure what to use.
  11. Dec 31, 2020 at 8:07 AM
    IvanhoeTaco
    Eastern NC
    I used the little brackets that normally attached it to the winch itself. With this setup I needed about 15 feet of battery cable to run it.
  12. Dec 31, 2020 at 8:11 AM
    IvanhoeTaco
    Eastern NC
  13. Dec 31, 2020 at 1:55 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Nice, I've always wanted to hard wire a switch to the cab just have never gotten around to it.
    6 gearT444E[QUOTED] likes this.
  14. Dec 31, 2020 at 1:57 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    That sure looks like my Badlands winch from Harbor Freight right down to the cooling fins on the motor and the stickers.
  15. Dec 31, 2020 at 1:59 PM
    IvanhoeTaco
    Eastern NC
    It's an xbull 13k. I'm sure it's the same Chinese slave labor
    BlessdApparel1[OP] and Grey 2015 like this.
  16. Dec 31, 2020 at 4:11 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I made a mount using where the ABS module bolts down in the fender well. It’s not hard to extend, there are even companies online that would make the cables for you, just give them the gauge, size of connector, length you need. Use a string to estimate new length.
  17. Dec 31, 2020 at 4:22 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Bigdaddy4760 likes this.
  18. Dec 31, 2020 at 6:18 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Yea I'm sure it is.
    IvanhoeTaco[QUOTED] likes this.
  19. Jan 1, 2021 at 11:19 AM
    BlessdApparel1
    Oceanside
    I’ll look into what i can find.
    I am gonna see if i can Fab something up today.
  20. Jan 1, 2021 at 11:20 AM
    BlessdApparel1
    Oceanside
    Naveronski[QUOTED] likes this.
