Winch Control Pack change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toycoma2021, Oct 3, 2023.
  1. Oct 3, 2023 at 5:16 PM
    Toycoma2021
    Toycoma2021 [OP] Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Bought a used Warn 9.5 XP winch. It is a complete unit with steel rope, control pack and wired remote. I'm doing some upgrades and one I wish to do is replace the 4-solenoid control pack with one of the newer integrated control packs.
    Warn produces their own control pack for their newer units, such as: Amazon.com: WARN 98381 Service Kit - Winch Contactor : Automotive at ~$95
    I'm wondering if anyone has any experience with the Amazon less expensive units available, such as: Amazon.com: 12V 500 AMP Unversal Winch Solenoid Relay Contactor For HEAVY DUTY UPGRADE ALBRIGHT EQUIV : Automotive at ~$35
    I have also completely taken apart the unit and removed all the old grease and regreased. Will be installing synthetic rope as well.
  2. Oct 3, 2023 at 6:05 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    while maybe 25% of the warn is branding markup, the rest is likely going go towards better materials in the product. the Amazon one likely cuts some corners in the metals used, likely also more lax qc process.
    it really depends on how much you end up using it. if you plan on using it nearly every day for hours at a time, the warn will be a better option. if you're only going to use it occasionally, the amazon one is likely going to work just fine.
  3. Oct 3, 2023 at 6:09 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I second this. Also worth considering is your need for the winch to operate? Do you go out by yourself and absolutely need the winch to work? Or do you ho out in groups with backup recovery options?
    My guess is that water intrusion and corrosion could be a risk of the cheaper unit.
  4. Oct 4, 2023 at 10:01 AM
    Toycoma2021
    Thanks all. Original factory is usually best, but sometimes aftermarket is adequate. I was looking for experience with the cheaper option. Went ahead and ordered the Warn. Do lots of trail winching moving trees.
  5. Oct 4, 2023 at 7:28 PM
    soundman98
    NW Indiana
    it's a different design, but if it helps at all, this is the unit included with the harbor freight winches.
    i took it apart for my own curiosity, and it's fully sealed with a silicone gasket, which means it shouldn't ever dryrot like a rubber o-ring would do.
    reallifedog likes this.
  6. Oct 4, 2023 at 9:23 PM
    Toycoma2021
    Thanks, I always like to look inside things too. Looks to be pretty similar to both the Warn and the other after-market controllers.
    soundman98[QUOTED] likes this.
