Winch Install Question??????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJYota, Apr 20, 2010.
  1. Apr 20, 2010 at 5:43 PM
    AJYota
    AJYota [OP] Member
    AJ
    Florida
    4x4 Tacoma
    4x4, three inch Toy Tech sup lift and Maxxis Big Horn tires 285 75 16
    My so has a 2007 Tacoma, 4x4 and I was wondering what is a cheap way, or is there to install a winch. He has a brushguard but it is not one of the ones that will hold up to a winch pulling on it (More for looks and lights).
    I was wondering if you could get something or build somthing to support the winch. I want it to look good but I also want to go the poor man's way.
    I saw Tractor Supply Company has a Champion 8000 winch for around 399.00.
    http://www.tractorsupply.com/winche...n-8000-lbs-pulling-capacity-winch-kit-1830068
    Thanks
    AJ
  2. Apr 20, 2010 at 7:11 PM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    NO!NO! You need a bumper that will work with a winch!!! try Warn.com and look at the transformer winch mount! I had one on my last ! It may work with your bumper!! And you can a Warn M8000 winch for about $600. You get what you pay for!!:D Good Luck!!!!
  3. Jul 14, 2011 at 9:43 PM
    jimmy12
    jimmy12 Well-Known Member
    midwest
    tacoma reg cab 4x4
    3"revtek lift 265 cooper discover st afe cai blackedout steel wheels warn m8000 winch mounted on custom hiddenwinchmount.
    Did you ever find a winchmount? If not check ou this website. Undercoverhwms.com this mount only weighs less then 30 lbs & is made to support a warn vr or m 8000lb winch. And it does all this with everything conceiled behind the factory bumpercover let me know what ya think?
