Winch is in the mail.. Wiring questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ItsPollan, Jun 29, 2021.
  1. Jun 29, 2021 at 10:53 AM
    #41
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Taco truck?
    vicali[QUOTED] likes this.
  2. Jun 29, 2021 at 11:11 AM
    #42
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    A safe, cheap and simple option is to attach the power cable to battery only when you are going to be using the winch, via a longer battery bolt and a thumb nut:
  3. Jun 29, 2021 at 11:14 AM
    #43
    dagobert
    dagobert Well-Known Member
    Looks like it comes down to peace of mind.
    So
    What is peace of mind worth to you?
  4. Jun 29, 2021 at 11:49 AM
    #44
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I used 3/4" heater hose to sleeve the pos (+) cable
  5. Jun 29, 2021 at 12:01 PM
    #45
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Like I mentioned I kept my winch wiring simple with no fuses , relays or high amp disconnects . I've seen way to many times of people over protecting a circuit and having it bite that person in the a**
    I've seen fuses blow prematurely for no reason whatsoever and stranding the vehicle and its occupants . Even my Drag race car with the battery in the trunk I've got the 12v pos wire running from the trunk to the engine compartment and it's only protection is a moroso high amp disconnect mounted on the tail panel
    JoeCOVA likes this.
  6. Jun 29, 2021 at 12:20 PM
    #46
    ItsPollan
    ItsPollan [OP] Active Member
    Thanks, Finally some good info here..
    Geeze, this thread turned into a shitshow quick
  7. Jun 29, 2021 at 1:52 PM
    #47
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Welcome to TW
    Enigma8246 likes this.
  8. Jun 29, 2021 at 3:03 PM
    #48
    OnHartung'sRoad
    I did put a switch on mine worried that someone would goof around with my winch and cause it to start up. I was also going to say there’s at least one post on the web how some Jeep guy’s winch solenoid shorted to ground and the current went back through his master cylinder due to a ground fault and caught the oil on fire in the metal sheathed brake line, but it was probably because it was a Jeep and not a Tacoma.:thumbsup:
