Winch mount or plate without a new bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dan98svt, Apr 1, 2010.
  1. Apr 1, 2010 at 5:58 AM
    dan98svt
    dan98svt [OP] Member
    Dan
    GA
    '10 MGM Tacoma DC SB 4x4 TRD
    Relocated Trailer Plug, Rear Spot Light, Light Bar w/4 KC Daylighters, BedRug (ordered), XM Radio,
    I want a winch, but do not want to change bumpers. I already have a light bar mounted to the frame through the bumper slots, so I don't need the whole grill guard thing... I just want a plate that bolts up through the bumper slots that will support a winch and pulling. I don't want to do the front tow hitch thing either. Any ideas or links?
    Thanks,
    Dan
  2. Apr 20, 2010 at 5:53 PM
    AJYota
    AJYota Member
    AJ
    Florida
    4x4 Tacoma
    4x4, three inch Toy Tech sup lift and Maxxis Big Horn tires 285 75 16
    I saw this question and thought I found the answer, but no replies. I need the same advise.
  3. Apr 20, 2010 at 6:56 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I saw somebody a while back that had a 2" receiver on the front of their tacoma. I know there are receiver winch mounts, i'll try a little google and see if I can find it.
    Edit: heres a thread. However from looking at the pricing you'd probably be better off w/ a new bumper
    http://www.toyotanation.com/forum/t143859.html
  4. Apr 20, 2010 at 7:03 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
  5. Apr 20, 2010 at 10:24 PM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    Check out Warn.com Warn makes a mounting plate, it may work for you!!Good luck!!!:thumbsup:
  6. Apr 20, 2010 at 10:44 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i vote weld a bud built winch channel to the frame behind the bumper
  7. Apr 20, 2010 at 10:54 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    If someone I can find someone local for a donor truck I could(and have been wanting to) make a winch mount that fits with the facory bumper. I was thinking one where you'd cut out the lower center part of the plastic, then bolt the mount assembly up. It would act as a tougher skid plate for the center, plus be able to hold a good winch and have the option for 2 recovery shackle points. Might even make it out of aluminum as an option?
