Winch recommendation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by icky crane, Aug 2, 2019.
  1. Aug 3, 2019 at 5:06 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Durability/long life. I started four wheeling in the eighties using wire rope and I've used it in various rescue/extrication classes and real life scenes along with some rigging classes so while synthetic does have a lot of advantages, it doesn't really bother me to use wire. I understand it's limitations and dangers and I have a very healthy respect for them. One plus is that it's less likely to be damaged by rocks or mud, both of which are common around here.
    Until recently, I was traveling a lot for work so I wasn't in the States as often meaning my truck sat for periods of time. When I travel here I'm usually alone so I purposefully avoid unnecessary risks as much as possible meaning it doesn't get used a lot. I want the security of the winch but there's no point in spending a couple hundred on a synthetic line that's going to need to be replaced every couple of years when a wire rope can sit for years with an occasional lubing and be fine. I've pulled out far more people than I have self recoveries and I've also used it for moving stuff around.
    Now that I'm back in the US if I find I'm using it more then I may switch to synthetic but other than the weight issue I haven't really thought much of it. Having watched a decent number of folks using their winches, especially younger folks who buy a 4wd and a winch and suddenly think they know what they're doing, I almost always recommend synthetic. The safety factor alone is worth it for most folks and most actual experts are smart to recommend it if for that reason alone. In my experience, a lot of the people with winches don't have much of a grasp on physics or understand just how dangerous a winch can be so removing at least one of those hazards is worthwhile. Even a lot of the tow truck operators don't really seem to know what they're doing and rely on the brute force of their winches or their trucks. Ever watched a tow truck pull a vehicle out of a ditch with a J hook in an iffy location or using a frame hook (transportation keys)?
    None of this should be construed as me being some sort of winching or extrication expert, I make no claims to that despite having a handful of certs in various areas. I have taken the time to try to learn from some folks who were experts though. Whatever the OP gets, I just hope he takes the time to learn some safe rigging practices and is careful. :thumbsup:
    Note: I do love soft shackles too!
    SR-71A likes this.
  2. Aug 3, 2019 at 5:13 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    X bull 13k
    ImMrCrash likes this.
  3. Aug 3, 2019 at 5:16 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    How many of you hard wired the toggle switch and mounted it in the dash ???? , makes for faster access to your winch
  4. Aug 3, 2019 at 6:00 PM
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    If he goes with my recommendation it has a wireless remote (along with a wired backup). Only plebs winch outside.
  5. Aug 3, 2019 at 6:19 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i have that same winch on my FJ40 :D
    i use a comeup winch on my taco and it hasnt let me down yet.
  6. Aug 3, 2019 at 6:43 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Same (recommend Smittybilt that is.. :D)
    No need to spend big money on a fancy name. Get one that fit your needs (9.5k lb is popular for these trucks), then figure out if the weight savings with synthetic line is worth the extra $ in your case.
    As long as you maintain it and follow the recommendation of cycling it once a month you should be good. And learn some basic winch safety as well
    I've only had to make like one real pull with my xrc 9.5 but it was a 200+ ft pull, up hill, through the snow. No problems
    icky crane[OP] likes this.
