Winch Suggestions for a Trail Gear Rock Defense Bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by GMcGee, Jan 10, 2021.
  1. Jan 10, 2021 at 6:57 PM
    GMcGee
    GMcGee [OP] Well-Known Member
    San Diego, CA
    2004 Tacoma 4x4 with Supercharged 3.4
    I’ll start by saying that I used the “search” function, but didn’t find anything. So, please let me know if I missed it somewhere. With that out of the way, I’m looking for suggestions from anyone with the Trail Gear Rock Defense Bumper (https://trail-gear.com/armor/rock-defense-front-tacoma-bumper-95-04.html). Of course, I want as much capability as I can, but fitment is my main concern. I’d like to avoid having to cut the grill, so I’m hoping one of you can answer my question.699F6BB7-BE2D-4F92-86FB-9310BAEA6FEE.jpg
    Thanks in advance, fellas!
  2. Jan 10, 2021 at 7:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, a winch is pretty standard in the way it fits so you won't find any recommendation for your specific bumper.
    Being that a winch is a tool, a powerful one at that, you should look at what type of fairlead you want, steel rope vs synthetic, rating, etc.
  3. Jan 10, 2021 at 7:02 PM
    KStateTaco
    KStateTaco Well-Known Member
    James
    Kansas City
    01 Reg Cab 4x4
    I have the smittybilt 9500 in a reg cab with that bumper. Fits without cutting but the winch clutch lever will interfere with the grill unless you clock the motor. It's recommended to regrease the motor anyway to make it easier to pull the line. Look up winch motor clocking to see what I mean
    alarka and GMcGee[OP] like this.
  4. Jan 10, 2021 at 7:10 PM
    GMcGee
    San Diego, CA
    I’m no expert, but I’m fairly certain that the way winches are mounted is standard. That said, fitment in a bumper will depend on the bumper itself. That is why I asked about fitment in my specific bumper. I’m limited to a hawse fair lead which is in the product description (the link that I included in my post). Soooo... Thanks for your reply?
  5. Jan 10, 2021 at 7:11 PM
    GMcGee
    San Diego, CA
    Thanks for the reply and recommendation! I’ve had my eye on the Smittybilt 9500, but wanted to hear from someone else with this bumper before pulling the trigger. I appreciate ya!
  6. Jan 10, 2021 at 7:16 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Your not limited to a Hawse. Just like winches have a standard mounting bolt pattern so do fairleads. Roller or Hawse have the same mounting points.
    If your looking to keep the weight down in the front end though get synthetic rope. Using it vs cable will cut 25 lbs off the winch weight.
    alarka likes this.
  7. Jan 10, 2021 at 7:20 PM
    GMcGee
    San Diego, CA
    Thanks for your reply, but as you can see, the manufacturer states that this bumper requires a hawse fairlead.
    alarka likes this.
  8. Jan 10, 2021 at 7:28 PM
    theesotericone
    Bishop CA
    They say it won't work because if you use a roller fairlead it would partially block the front hitch receiver. So you'd loose the ability to connect a hitch to it. Makes sense why the would say to only use a Hawse because of how close the receiver is to the mount. I assure you the bolt pattern in that bumper would accept a roller fairlead though.
    GMcGee[QUOTED][OP] likes this.
  9. Jan 10, 2021 at 7:30 PM
    GMcGee
    San Diego, CA
    I have no doubt the bolt patterns are the same, but that still doesn’t address my actual concern of fitment in order to avoid trimming the grill. I appreciate your inputs, though.
  10. Jan 10, 2021 at 7:34 PM
    theesotericone
    Bishop CA
    It doesn't look like anything is in the way on the side to prevent any winch from fitting length wise. I get your worried about the height but it's very easy to relocate the control box if it interferes with the grill in the height axis.
    Every winch made has full specs of it's size showing length and height. I'd just take out a tape and measure your clearance from the winch tray to the bottom of the grill. Then pick a few winches you are interested in and compare the numbers. That tray is so wide open any winch should work though.
  11. Jan 11, 2021 at 3:47 AM
    KStateTaco
    James
    Kansas City
    01 Reg Cab 4x4
    No problem! For the record, the trail gear bumper won't fit a roller fairlead. The dom tubing above the fairlead mount would get in the way. To fit a roller fairlead you would need to cut into that tubing. Make sure to get a synthetic line and hawse fairlead.
    And winch height can be an issue. The smitybilt 9500 comes real close to the grill. Maybe half an inch of clearance. If you want something beefier, compare it the height of the 9500.
  12. Jan 28, 2021 at 10:31 AM
    dirtbagtaco69
    dirtbagtaco69 Active Member
    Alberta
    1981 Toyota Pickup Diesel 4x4 35's
    Could you get a steel Hawse fairlead to use with a cable winch? I'm pretty adamant on using cable since I wheel in mud and rocks occasionally and don't want to clean the line after every trip if I don't have to. Plus it's more robust for the stuff that I'm looking to do
  13. Jan 28, 2021 at 11:14 AM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Noticed a 2" receiver on the front of your rig, have you ever considered getting a winch cradle? That way you can use the winch on the front or the back plus have the ability to store it in a cool dry place when not needed.
  14. Jan 28, 2021 at 11:22 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    The bolt pattern might fit, but it looks like a roller fairlead wouldn't fit because of the upper tube in such close proximity, not because it would overlap the hitch receiver.
  15. Jan 28, 2021 at 11:50 AM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    If I am reading the original post correctly, I am under the impression that the OP is concerned about the winch control box interfering with the grill. IF that is the case, the simple answer seems to be to make sure to choose a winch that does not have an integrated control box that can be mounted either above the winch motor, or remotely to avoid any interference with the grill.
    Once you've narrowed that down actual winch selection only has a few things to consider. You'll want a winch capable of 1.5 times the loaded weight of your vehicle. 9k is just about perfect for most Tacomas. If you choose steel cable over rope, make sure your hawse fairlead is also steel.
    I've killed in order, a Harbor Freight winch, a T-Max winch, 2 smittybilt winches, and a Superwinch. Of the 2 Warns I've owned and used over the years, they're still going strong, and I'm currently running a Warn Zeon Platinum 12s. But your preference and budget will dictate what brand you choose.
    alarka and Kwikvette like this.
  16. Jan 28, 2021 at 5:49 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Pretty much ALL winches will fit that bumper. It's a TG tube bumper, there's not a lot there to cause interference.
    The only thing you really need to consider is how the control box in mounted. Some are permanently mounted on top, others can either be rotated or removed entirely.
    For example, I have a Warn VR10, and it has a top mounted control box, but it CAN be remotely located. I chose not to because the wiring and finding a remote location in the engine compartment was more a pain in the ass than simply hacking up the grill. So that's what I did.
    Also of note is that mine came with a Hawse, even as a steel cable winch. You don't NEED a roller with a steel cable...
  17. Jan 28, 2021 at 9:19 PM
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    Bro! what worked for me was.....
    Warn Steel Fairlead. Do not use aluminum. Got it on eBay for $35.
    You will loose the front hitch ability though.
  18. Jan 28, 2021 at 9:38 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Using HF discount code 66384901, the winch comes out to $312 shipped (cheaper than their 9k winch). Swap the steel cable with Synthetic Rope and add an Aluminum Hawes Fairlead for $99 from Amazon = $411 shipped to your door. :notsure:
    Alternatively, using HF discount code 37998045, the with synthetic rope = $531 shipped to your door :thumbsup:
    Tttacodan likes this.
  19. Jan 29, 2021 at 11:04 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Trimed with smittybilt 10k. Had to take the grill off to put it on.20190117_154901.jpg
  20. Jan 29, 2021 at 12:04 PM
    RyanDCLB
    4/19 DCLBOR
    I didn't realize it was that tight of a fit. I have the same winch. It almost looks like the control panel could be relocated, and the housing could be "clocked" to put the clutch lever in the rear, and it might fit without trimming the grille?
