Winch Syn. change from steel line
Discussion in 'Technical Chat' started by OH-MAN, Apr 15, 2011.
  1. Apr 15, 2011 at 8:05 AM
    OH-MAN
    OH-MAN [OP] Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I purchased a superwinch equiped with steel cable and am going to replace with syn.
    The fairlead is the steel roller type.
    Do I need to change the rollers to the delrin/poly style or will the syn. line be OK with the steel rollers?
    Not really wanting to use the billet non roller style fairlead.
  2. Apr 15, 2011 at 8:08 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You dont have to change, but its easier then trying to untangle 50' of synthethic rope out of your fair lead rollers :D
  3. Apr 15, 2011 at 8:38 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Not quite sure what you meen.
    Will the syn line get in between the rollers and cause a big problem?
    So the non roller is the way to go?
  4. Apr 15, 2011 at 8:39 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You need a aluminum fair lead for the Syn line.
  5. Apr 18, 2011 at 6:22 PM
    DevL
    DevL Well-Known Member
    They make Delrin rollers for synthetic line. Yes, you need to change fairlead ASAP. It saves a ton more weight too.
