Winch synthetic/steel vs pull force trade off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arwinnnsd, May 20, 2017.
  1. May 20, 2017 at 3:51 PM
    arwinnnsd
    arwinnnsd [OP] Rockin the Death Train!!!
    Alexander
    Woo, MA
    The Death Train!!!
    BFG All-Terrain KO2s Pelfreybilt Al triple loop plate bumper Warn Zeon 8-S winch EBC Brake Kit - S5 Yellowstuff and GD Rotors Custom kick out rock sliders
    Hey all,
    I don't know if I just suck at searching on here, but I'm not finding the info I'm looking for... I'm looking to get a Warn Zeon winch but I'm not a millionaire, so I'm in between the 8s or the 10 (steel). Please don't try and convince me of another winch unless it is 1. waterproof 2. manufactured in the US 3. a warn zeon :)
    Is synthetic a better upgrade than the extra pull? I live in the dirty-T (tucson, AZ) so I'm a little concerned with the UV and synthetic, but maybe this is a dumb concern. My thoughts are that the 8s ($842) weighs less, but the 10 steel ($704) I can upgrade to synthetic in the future, but it will cost at least an extra $372 to upgrade, making it $1076. Is the 10 kips load capacity over kill (kip = 1000 Lbs)? Any help with this would be much appreciated.
    Thanks all!
  2. May 20, 2017 at 3:58 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Get the 8s and use snatch blocks to increase pull if you need to. UV is pretty much a non-issue in a bumper mounted winch.
  3. May 20, 2017 at 3:59 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I went with a Zeon 8S. A snatch block will give you the all pulling power you need and allow you to run out most of the winch line which is needed to attain peak pulling power.
    bullaculla likes this.
  4. May 20, 2017 at 4:02 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
  5. May 20, 2017 at 5:12 PM
    arwinnnsd
    Alexander
    Woo, MA
    The Death Train!!!
    Damn Landphil... You just opened a whole new can of worms... (in a good way)
    so the price point is very nice on the Runva, and at 14200 Lbs (vs 14400) its just as strong. But warn only warranties spydura, but further investigation led me to Warn's recommendation that you change the synthetic rope every 12 months; WTF! I know that it will last waaaayyyyyy longer than 12 months, but it that some crap they use to get out of warranty? If so wouldn't Steel be the safer bet?
    I've never used synthetic, all my family buys steel cable; but then again they all drive dodge :)
  6. May 20, 2017 at 5:19 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Steel does have advantages, but for me, the weight and safety of synthetic line outweighed the disadvantages. I wasn't concerned about warranty, though it was strong enough to briefly stall (2nd wrap) my M8000 with no ill effects.
    Just to be clear, I was only recommending the Runva line (and their aluminum fairleads are sweet too), not their winches - I have no experience with them.
  7. May 20, 2017 at 5:36 PM
    arwinnnsd
    Alexander
    Woo, MA
    The Death Train!!!
    hmmm... I don't want to sound like a dumb ass, but I'm just a nervous spender (cause I'm usually Cheap!)
    you run a M8000 which is equivalent to the zeon 8, so I'm assuming you allong with everyone else here so far feels that the 8 kips is enough. Zeon 8s = $841.93 (after rebate). Zeon 8 + Runva rope and fairleads = 727.03 + 129 + 30 = 886.03. Current Warn prices on Amazon after Warn rebate. Note that the prices change all the f'in time, its like the stock market.
    So to me its seems that--since everyone so far is unanimous about synthetic--the best option is too start with the 8s. Then when it become time to replace the rope in x amount of years, look into after market, e.g. Runva.
    Another question for everyone: have you had to change your synthetic rope? How often? Please provide climate and usage rating e.g. light/medium/heavy or other game changers like salted roads.
    Thanks again to all of you, this has been helpful in my decision making
  8. May 21, 2017 at 1:05 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    All it says is "synthetic", no mention of exactly which synthetic fibre (there are thousands) or who made it. It is most likely UHMWPE (Ultra-high-molecular-weight polyethylene), but I'd want to know for sure, and who made it...
  9. May 21, 2017 at 1:15 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    It is indeed UHMWPE, I do recall that much.
    I never had to replace it, in 2 years it was on the Tacoma I used it 3 or 4 times, with no ill effects or signs of deterioration. It's been sitting in my shop since the wreck that totalled my Tacoma last fall.
  10. May 21, 2017 at 1:49 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    UHMWPE has good UV resistance, its main "enemy" is heat but even there it is safe to use at 175° to 210° F.
    The good thing about rope vs. cable is that when rope breaks it snap back in a straight line and then just slumps to the ground; anyone standing next to it would likely have to go home and change their undies, but they wouldn't be badly cut-up or dead..
    Cable however rarely breaks cleanly. One or two strands will break and then unwind flailing out 8 to 10 ft or more. People standing next to that have been cut-up badly and even decapitated.
    Here's a good video showing the difference in how they break. Keep in mind also that in this test the anchor points of the tensile strength tester stop moving when the cable breaks--imagine how those broken strands would fly about if connected to a stuck truck and another pulling its brains out that keeps on pulling even after the first strands break...
    landphil[QUOTED] likes this.
