Winch wiring
Discussion in 'Recovery' started by GARSHA91, Aug 5, 2018.
  1. Aug 5, 2018 at 8:42 AM
    GARSHA91
    GARSHA91 [OP] YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    anyone know what’s needed to install a winch and hook it up to a power switch?
    Also I have an in/out switch from otrattw.net and was wondering if anyone knew how to wire that up. Thanks!!
  2. Aug 5, 2018 at 9:07 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    What type of winch? They all wire stuff a little differently
  3. Aug 5, 2018 at 9:15 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Ensure the switch and the wire can handle the amps. A winch can easily draw 400 amps. Also ensure your battery is up to the task.
  4. Aug 5, 2018 at 9:22 AM
    GARSHA91
    Chicago
    It’s a warn vr12s
    Bluegrass Taco likes this.
  5. Aug 5, 2018 at 9:30 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I have a VR12s too, they are rated at 460amps, so I put one of these next to my battery to power the winch on and off. It’s rated up to 600amps (for 5 minutes) or 350amps (continuous) and it’s marine rated waterproof.
    https://www.bluesea.com/products/9003e/e-Series_On_Off_Battery_Switch
    They are ugly but work well for heavy amp requirements. Mine is mounted between the battery and the brake master cylinder on the empty threaded holes in the fender wall using heavy duty L brackets. I’ll post a pic later today.
    Another option you may consider is using a heavy duty relay and turning it on and off with a small toggle switch in the cab. Be sure to get a relay that can handle up to 500 amps @12v or so...
  6. Aug 5, 2018 at 12:03 PM
    rnish
    Tacoma 2nd gen
    Switch pics:
    Opmsport and GARSHA91[OP] like this.
  7. Aug 5, 2018 at 4:10 PM
    GARSHA91
    Chicago
    Thanks for the photos although I’d have to mount it somewhere else bc I have my fuses and relays in that position
  8. Aug 5, 2018 at 7:01 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    You have options. Personally I’d wire it straight to the main battery. When you add switches and breakers you are increasing the power loss due to resistance.
    As for the switch, find the wiring diagram of how the switch goes. Or open up the solenoid cover to see what wires you need to tap. Typically you’ll need a hot, winch in, and winch out. If you want lights on the switch to work then you’ll need a ground.
    GARSHA91[OP] likes this.
  9. Aug 5, 2018 at 7:13 PM
    GARSHA91
    Chicago
    I have the switch lit up. I just need to find the ones to tap into I guess then. Thanks.
