Winch Won't Freewheel
Discussion in 'Recovery' started by Tactical_Panda, Jul 26, 2023.
  1. Jul 26, 2023 at 6:25 AM
    Tactical_Panda
    Tactical_Panda [OP] Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    I have a Smittybilt X20 12,000 winch (nylon rope version). I have not used it since last year and I just wanted to make sure everything is still working properly.
    I put the winch in Freewheel but the rope won't unspool no matter how hard I try.
    Any thoughts?
  2. Jul 26, 2023 at 6:49 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Anchor the rope and back the truck up slowly in free spool? Can you use the controller to verify the drum will turn?
    ToyoTaco25 likes this.
  3. Jul 26, 2023 at 10:28 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Can you power the line out with the controller? (Will the drum spin?)
  4. Jul 26, 2023 at 10:47 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Second both opinions above. Make sure the drum will power out. If so, tie off to a tree, double check you are in freespool, and back the truck up to spool off almost all the line.
    Inspect, clean, and dry the line as needed. Then spool it all back in neatly with a light load on the line.
    The Smittybilt users manual for my 9500 lbs winch specifically says to spool in / out once a month. And to spool it in with a light load. I have noticed over the years that not running it for a while makes it hard to unwind, similarly after a heavy pull it can be hard to unwind
    Bivouac and jlemmond like this.
