winch
Discussion in 'Off-Roading & Trails' started by ihateBL, Mar 5, 2015.
  1. Mar 5, 2015 at 5:32 PM
    ihateBL
    ihateBL [OP] Call Me Dad
    Inmate C-9523
    The Last Best Place
    2010 Pre-runner sr5 d-cab(K.I.A.), 2011 DCSB TRD-OR
    All Pro "Apex" Susp., 12.5k, Armor all around, 34's
    best winch for under 500?:eek:
  2. Mar 20, 2015 at 12:10 PM
    Pigpen
    Dan
    Northwest Montana
    Keep saving
  3. Mar 20, 2015 at 12:15 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  4. Mar 20, 2015 at 3:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    The phrase...You get what you paid for...comes to mind here. :D
  5. Mar 20, 2015 at 3:08 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I bought the engo 10000s and got it for $429 shipped. Great reviews online and it did awesome in the 4wheel parts winch shoot out.
  6. Mar 20, 2015 at 3:50 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    X3 on Keep saving. And personally I don't trust anything recommended by 4Wheel Parts. Their recommendations are driving 100% by advertising $.
  7. Mar 20, 2015 at 4:41 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    I've seen harbor freight winches work for many years. If the reviews look good then why not give it a chance.
  8. Mar 20, 2015 at 6:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    A winch is the one thing I wouldn't recommend skimping on, it could mean the difference between driving out of the woods and walking out. You need to be able to depend on it when you're in the absolute worst possible situation, and that's exactly when a budget winch will fail.
  9. Mar 20, 2015 at 6:18 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    I love my smittybilt 9500 xrc comp. I bought it new in box for 300 on craigslist, then swapped out the grease. Great winch, cost effective, synthetic line, waterproof. Otherwise I'd buy a ~$1000 Warn.
  10. Mar 20, 2015 at 7:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Daily driver or trail rig?
    If a daily driver, that winch will get more abuse just sitting on your bumper doing nothing. I've killed three winches and each one did no more than 10 pulls. Michigan winters are hard as hell with all the salt being blown into them constantly. On my daily drivers, I put t h e cheapest I can find. Harbor Freight winches are just fine for me.
    If the winch is going on a dedicated trail rig, I have no issue spending the big dollars. It will be used in its designed environment.
    If you are doing research, find out which ones have replaceable motors, the motors are the thing that fails. In many cases you can't find a motor cheaper than you can buy a whole new winch for.
  11. Mar 24, 2015 at 8:24 AM
    Pigpen
    Dan
    Northwest Montana
    One of the reasons mine lives in the back of the truck
  12. Apr 22, 2015 at 7:49 PM
    creep
    creep Member
    Casey
    Little Rock, AR
    Have you looked at the used route? I see quite a few name brand winches selling for cheap on Craigslist regularly.
    Sometimes they can be bought for nearly nothing since the owner didn't want to fool with a bad solenoid or something simple like that.
  13. Apr 22, 2015 at 7:56 PM
    GZeus24
    GZeus24 bystander
    Gary
    Texas
    2014 DCLB Sport
    lightly modified
