Winches and pumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Benny blanco, Jun 2, 2021.
  1. Jun 2, 2021 at 9:03 AM
    Benny blanco
    Benny blanco [OP] Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I’m not really afraid of the smaller wiring projects, but this one has me a little nervous. Basically I’m wondering if it’s bad to direct connect both a winch as well as a air compressor to the battery, they have in line fuses.
    Obv they won’t be being used at the same time, unless there is some sort of f-up.
  2. Jun 2, 2021 at 9:29 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Why would that be bad?
    Mully likes this.
  3. Jun 2, 2021 at 9:30 AM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I don’t know. That’s why I’m asking. Just seems a little 6435A0BB-A306-43A5-A4B9-ED6A771FFBF5.jpg like this
    CttAznRanger likes this.
  4. Jun 2, 2021 at 9:32 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Haha, nice pic. That is probably the best way from a electrical isolation standpoint. As long as they have some sort of circuit protection then direct to battery is no problem. I think most winch manufacturers recommend that they are connected directly to the battery.
    Mully likes this.
  5. Jun 2, 2021 at 9:33 AM
    tetten
    Andy
    Socal
    Just make sure all the wiring is secured so it doesn't wear through from vibration on adjacent components and your fuses/breakers are installed properly it should be good.
  6. Jun 2, 2021 at 9:33 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
  7. Jun 2, 2021 at 9:38 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    No issue with the air compressor. But good luck finding a reliable fuse big enough to protect a winch. Thats why most folks go direct to the battery without any overcurrent device for winches
    Benny blanco[OP] likes this.
  8. Jun 2, 2021 at 9:39 AM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I like that switch. Thanks for the info. Also I’m still laughing about twat waffles
    I’d be tearing apart the front end right now but my winch is in transit someplace. Guess I’ll start with the compressor then
  9. Jun 2, 2021 at 10:19 AM
    littlefish
    Hudson Valley NY
    No reason you can't do them separately. Like @SR-71A said you won't find an inline fuse big enough for the winch, but the switch has given me some peace of mind that there isn't 2AWG wires hot upfront in case of an accident.
  10. Jun 2, 2021 at 2:47 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Larger and smaller sizes of fuses and breakers are available.
    400A Fuse
    https://www.amazon.ca/Baomain-ANL-400A-Electrical-Protection-Fuse/dp/B01MYPSLRV
    400A Breaker
    https://www.amazon.ca/400-AMP-12-VOLT-CIRCUIT-GETWIREDUSA-148-400A/dp/B019GHCGOK
    If you have no protection on the circuit ... and a wire rubs through the insulation... you will have a fire.
    If you have just a switch,
    and the main wire is damaged and you have a dead short... You will have upto/over (depending on battery/ wire size/ length etc) 1000A flowing of fault current.
    Well drop some #2 bare copper across some battery terminals (from a VERY safe long distance, ) and see what happens.... (don't do it)
    At best you have a huge bang and the wire blows off the terminals spraying plasma and hot wire,
    At worst the battery "explodes"
    A switch may weld itself closed during a fault,
    and even if you had not jumped 10 feet away from the bang and sparks you may not be able to open the circuit again even if it was not heating up and melting with all the fault current.
    For my 10K winch, I use a 250A breaker.
    Yes at a full 10K load it will draw over 250A.
    But the trip curve on that breaker shows that it would take 300 seconds before it would trip at 400 amps.
    But here is something most people don't know about breakers, they have what is called a "trip curve "
    This isn't the graph from my breaker, but an example (different for each brand and model)
    This 100A breaker could be loaded to 300A and it would take 5-13 Seconds before it will trip.
    Dead short would be under a second.
  11. Jun 2, 2021 at 3:44 PM
    littlefish
    Hudson Valley NY
    Can you explain the part I made bold a little more? You mean the wire downstream of the switch between the switch and the winch? That event would happen in the case of the short happening, and the switch being turned on, correct?
  12. Jun 2, 2021 at 3:58 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Any type of short will draw an extremely high current until something happens to clear the fault. That "something" will be 1) battery exploding, 2) wire burning into or 3) Fuse protection device clearing.
  13. Jun 2, 2021 at 4:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m curious as well because if the switch is off, that doesn’t make sense.
  14. Jun 2, 2021 at 4:17 PM
    PhenixFord
    Randy
    Arkansas
    Guess that depends on where the switch is and where the short happens. But yeah - switch ON. If you use a switch?
    EDIT: Wait, Are we talking Battery Switch? Or Winch Controls?
  15. Jun 2, 2021 at 4:29 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I put a (600 amp) disconnect between my winch and battery. Its a “Blue Seas” marine diesel disconnect.
    SR-71A likes this.
  16. Jun 2, 2021 at 4:30 PM
    littlefish
    Hudson Valley NY
    I’m talking a winch control solenoid switch. I have a short (~4”) 2AWG wire to the solenoid then everything downstream of that isn’t hot until I turn on the switch. Main thinking is in case of an accident the live wires upfront won’t be hot.
    Paulndot likes this.
  17. Jun 2, 2021 at 4:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A lot of people will put a simple ON-OFF 500a switch on the positive cable of a winch. They’ll put it near the battery. That way there’s not a long, hot lead at the front of your truck for every day driving.
    What littlefish and I are clarifying is that if the switch is OFF, then there is no risk of it shorting out past the switch.
  18. Jun 2, 2021 at 4:36 PM
    PhenixFord
    Randy
    Arkansas
    OK. Just making sure that someone didn't think that everything was safe as long as the winch wasn't in operation? :D
    A switch is nice to have. But, considering the cost of each, I would recommend a fuse only. Because A) you might forget to turn the switch OFF. And B) although only remotely, you could have an issue while the winch IS in operation. When the sparks start flying, it's very hard to reach into the fire to throw the switch. I've been there and done that.
  19. Jun 2, 2021 at 4:41 PM
    littlefish
    Hudson Valley NY
    Ok yes I follow that. Apples to apples the breaker is superior in terms of safety. Your 250A breaker doesn’t trip under a hard pull?
  20. Jun 2, 2021 at 5:11 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Correct, nothing happens if there is a short in the wire after the switch and it is in the OFF position.
    If the heavy wire was rubbed through and resting against thin sheet metal when you turn the switch ON, chances are there will be a big bang, some sparks and the thin metal and some of the copper wire will be blown away and clear the fault and you will be able to turn the switch back off (then going to change your underwear).
    If you have a heavy gauge wire and it's hard up against some thick steel, if something does not immediately go boom,
    you will see that nice big wire start to smoke as the insulation starts burning off the glowing red copper,
    there is also a good chance that the amperage from the fault caused an arc inside the switch and welded the contacts closed.
    I think the 24F batteries were something like 620 CCA (something like that)
    The test specifies that the battery at a temperature of –18°C will deliver a current equal to the Cold Cranking Amps for 30 seconds with the voltage staying above 7.2 volts.
    The immediate fault amperage of a fully charged warm battery.... lets say 1000A for an easy number to work with.
    Not an exact number, as there are too many variables, but gives an idea of why batteries have to be taken seriously.
    Quick youtube video search
    Vaporizing a nail.
    Batteries have vents to hopefully release over pressure...
    So in a best case scenario when your car battery is in a closed fault condition it looks like this...
