Wind coming through drivers side door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jojee117, Jan 16, 2019.
  1. Jan 16, 2019 at 10:40 AM
    Jojee117
    Jojee117 [OP] Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Wind has started coming through my drivers side door on my 2nd gen, but everything seems ok. I dont know specifically what to check for, but the weather seals aren't cracked and are still properly anchored to the door and b pillar. Its also started raining here in CA a bit, so I checked to see if any water is leaking through the seal, and theres nothing. Has anyone else had similar issues?
  2. Jan 16, 2019 at 10:42 AM
    BradsTaco
    BradsTaco Well-Known Member
    Texas/Montana/Florida
    2014 TRD 4x4 DCLB
    Sounds like a kazoo?
  3. Jan 16, 2019 at 10:44 AM
    Jojee117
    Joe
    MT
    It's strange, but actually theres no wind noise at all, just a really cold breeze obviously coming from outside and I can feel it coming through the back of the door.
  4. Jan 16, 2019 at 11:03 AM
    Muddinfun
    Muddinfun Well-Known Member
    Has somebody unlocked it with lockout tools? The air wedges that are used to open up a gap at the back of the door window frame can bend the door slightly. If that's the case, you just put your knee on the metal part of the door near the latch, grab the window frame near the top and yank back. Obviously, this is one of those cases where you yank gently, close the door and check, then do the same thing and yank a little harder, till the door fits right.
  5. Jan 16, 2019 at 12:50 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Is the window rolled up? :rofl:
    Lester Lugnut and tcjacado like this.
  6. Jan 16, 2019 at 1:17 PM
    MSGtacoMedic
    MSGtacoMedic Member
    MIKE
    2015 Prerunner SR5 DCSB
    Added Skid Plate, Tiger Armor Steps, MX2 Bakflip, Curt Hitch/ Harness; 2nd Air Filter mod , drain hose mod, knob mod, seat mod, , OEM Bed mat, tailgate debadge', fog light install / mod.;Door Seal Noise Fix Mod.
    The wind noise on the Tacoma is a known issue that Toyota is aware of and has a Service Notice out . This is the problem the customer must take it in and they must diagnose that it is the door seal. They have replacement doors seals that are thicker at the top , then the Factory ones. I fixed mine with the posted TW forum by using dip tubing 3/8" inserted inside to top of door seal. This fixed a problem with air , whistle, noise at highway speeds with cross winds. This is documented and works. Good luck!
    Jojee117[OP] likes this.
  7. Jan 16, 2019 at 1:23 PM
    MSGtacoMedic
    MSGtacoMedic Member
    MIKE
    Update, check out TW discussion. '15 ST5 DCSB Wind Noise (SOLVED!!!!). Old Timer gives options and the irrigation tubing fixed my problem.
  8. Jan 16, 2019 at 1:36 PM
    Jojee117
    Joe
    MT
    To my knowledge that has never been done, albeit I got the truck used. Nevertheless this just started and it seems to come and go which is strange
  9. Jan 16, 2019 at 1:37 PM
    Jojee117
    Joe
    MT
    I even made sure the door was closed too! Lol
    Bebop[QUOTED] likes this.
  10. Jan 16, 2019 at 1:49 PM
    Jojee117
    Joe
    MT
    After looking through that discussion I suppose it's common on the a pillar. Next time I take the freeway and notice it coming from the B pillar, I'll check the A one as well. Looks like bending the door a tad is the solution
  11. Jan 16, 2019 at 2:23 PM
    MSGtacoMedic
    MSGtacoMedic Member
    MIKE
    Please don't bend. $5 irrigation tubing from Lowe's at the top , inset through-existing hole in the door seal...if doesn't fix then pull it out....use spray lubricate and takes than 10-15 min tops.....I was only did drivers side ,but have enough to do all doors if needed...win win
  12. Jan 16, 2019 at 2:40 PM
    Muddinfun
    If it needs to be bent, it will be obvious. If the window frame is sticking out farther that the adjacent frame, it needs to be bent.
  13. Jan 16, 2019 at 3:02 PM
    Jojee117
    Joe
    MT
    I'll give the tubing a try
