Wind & Highway Speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A7XTaco, Oct 28, 2010.
  1. Oct 28, 2010 at 1:04 AM
    A7XTaco
    A7XTaco [OP] Member
    Bryan
    Austin, TX
    You don't want to know...
    Do you have to fight to keep your taco tracking straight at highway speeds when there is some cross wind? Or do I need to get the dealer to make another stab at a front end alignment?
    UPDATE
    : So I installed TRD Off Road shocks (Prerunner springs). This seems to have made a huge difference in how the truck handles.
    Before, the steering wheel would get very loose if there was any wind or buffeting. Now the steering stays tight and heavy, like the truck actually weighs 4000lbs, not leaf being blown around in the wind.
    I was banking on the floating being due to body roll, and at this point it seems that assumption was correct.
    I love my taco, but it was very uncomfortable to drive above 55... now, I love it! I can kick back with one hand on the wheel and not worry about ending up in the ditch!
  2. Oct 28, 2010 at 1:08 AM
    JanBoothius
    JanBoothius Taco abuse specialist
    Jan (Pronounced Yon)
    Salt Lake City, UT/Upstate New York
    '10 TRD Off Road Access Cab, 6 speed
    OME lift, 886 coils, Dakars w/AAL ARB front bumper, Warn M8000 winch Toyo Open Country MT 285/75R17 (34) Leer 180CC cap etc etc etc $
    When storms roll through Utah, I notice that the truck gets buffeted by the wind. The truck is completely stock, but this happens almost every time the wind is blowing. I used to drive a Subaru Impreza wagon, and the same thing would happen. I think it's just physics... but then again, the truck is stock with 7.5k miles on it.
  3. Oct 28, 2010 at 1:22 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Kind of...but it's not too bad. It's worse with my 4Runner though.
  4. Oct 28, 2010 at 1:40 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, it gets pushed around a lot, I figure it is just because the back is so light.
  5. Oct 28, 2010 at 1:41 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    try drivin a jeep wrangler in a good crosswind......whew
  6. Oct 28, 2010 at 2:02 AM
    supataco
    supataco Shaq-enzy Falls
    Ichiro
    Oahu - Hawaii
    2010-SSM-AC-TRDSport-PreRunner
    -17" 4Runner Trail Wheels (265/70/17) -OEM Tube Steps -Tailgate Security Clamps -Trimmed Mudflaps -Bed Bar -Kobalt Box -Bed Mat -Toyota Mats
    Wind speeds aren't even big in Hawaii, but I still feel it.
  7. Oct 28, 2010 at 2:40 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    It's worse when you have a canopy- More surface area!
  8. Oct 28, 2010 at 7:01 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My truck seems to want to move around with the wind blowing as well. Just a light truck, and I can see the topper compounding the issue
  9. Oct 28, 2010 at 7:19 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Yeah, my 03 taco blew around on the highway and so does this one... Just pretty light trucks and so a decent wind will turn these things into a sailboat in no time. You should see what the wind does to my parents excursion though when the wind starts whipping through. Insane
  10. Oct 28, 2010 at 8:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    On my 09 DC I never had to fight the wind to keep it straight, but it always felt "skitish" in the wind. Would still drive straight, but it would feel like the body was being moved around a bit. That was stock.
    I've since added 5100s all around (fronts at .85 lift), TSB rear springs, larger tires (265-70/16 from 245-75-16), and an alignment where I specified the setting at 0/0/2.1. Since then it is much much better. Can still feel some movement, but not the old Caddy floaty thing like before.
  11. Oct 28, 2010 at 8:09 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Mine also wonders when driving across the Salt Flats towards Salt Lake City.:cool:
  12. Oct 28, 2010 at 3:04 PM
    A7XTaco
    A7XTaco [OP] Member
    Bryan
    Austin, TX
    Thanks for the input guys. I guess it just the nature of the beast. I'm sure it doesn't help that until mine grows into a TRD:pray:, the 4cyl makes it even lighter in the front end.
  13. Oct 29, 2010 at 7:22 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    I use to drive my friends xj a lot on the interstate and it had the auto merge feature in high winds it would really really scare you the first time it happened.
    Anyone noticed that the hood seems to wave at like 75mph and driving in a crosswind?
  14. Oct 29, 2010 at 7:26 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    It's no better or worse than any other truck that I've driven over the years. They sit high and have no weight in the back end so they are going to get blown around a bit.
  15. Oct 29, 2010 at 7:54 AM
    claw
    claw Well-Known Member
    Cam
    Bozeman MT
    2010 Access Cab, 4 Banger
    Tonneau cover, bed lights, fog lights, VHF radio
    Since a Suzuki Vitara was my last car (it would blow everywhere) the truck is great! At 90 MPH and severe cross winds it started to be as bad as the vitara, but I'll take it!
  16. Oct 29, 2010 at 8:15 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    Beefier Taco suspension helps with wind gusts on the roads while driving. I installed an inexpensive $25 -autozone-helper spring set up forward of the axle under the taco and it helped a bunch with wind on the roads. The way I installed it,the spring serves as a sway bar instead of load capacity enhancer,as it was designed for...
  17. Oct 29, 2010 at 9:20 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    trd sport 4x4... my other cars blow around on a certain part of the coast that are always windy... don't feel it in my truck.
  18. Oct 29, 2010 at 10:06 AM
    Tidrow
    Tidrow Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    Yep, does it happen on the passenger side? That's were mine waves.
  19. Dec 27, 2010 at 1:20 AM
    A7XTaco
    A7XTaco [OP] Member
    Bryan
    Austin, TX
    UPDATE: So I installed TRD Off Road shocks (Prerunner springs). This seems to have made a huge difference in how the truck handles.
  20. Dec 27, 2010 at 2:04 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    It's like this with any vehicle. Especially one that has more side sirface area, such as trucks.
    Try driving a tractor trailer with a 53' van trailer...
