Wind Messed Up My Door, Any Ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoJonn, Mar 17, 2017.
  1. Mar 17, 2017 at 8:26 AM
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    So I was opening up my door the other day and HUGE gust of wind came and blew door away from me. It made a weird sound so I knew it was bad. I live in Wyoming. The wind can be brutal here, especially this time of year.
    When I closed the door it made a popping sound. I couldn't tell where the popping sound was coming from but after closing it 5 or 6 times the popping sound stopped.
    I thought I was in the clear (but in the back of my head I knew I wasn't).When I later went to roll down my window, it only would go down 1/4 of the way before stopping, seemingly due to friction of something preventing it from going down all the way.
    Curious if anyone knows what is going on. Going to have to get it fixed regardless but wonder why this happened.
    Thanks in advance!
  2. Mar 17, 2017 at 8:34 AM
    pyrobobd
    pyrobobd Active Member
    Bob
    Southeast Colorado
    '07 basic truck
    Variable speed wiper switch
    Oh yeah, BTDT. You have bent the window channel inside the door, its mounting and probably the top door hinge. Take it to your favorite body shop now, 'cause it ain't going to get any better by itself. When the southern Colorado wind got mine, we ended up having to get new parts. That wind bang is violent enough to bend and break stuff beyond repair.
    Sorry to hear that,
    Bob
  3. Mar 17, 2017 at 8:35 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Just off the wall maybe a wire harness got yanked? Easiest thing to do is pull the door panel and take a look. It's super easy.
    This is a speaker install thread but it has detailed step by step on panel removal. Takes like all of 5 min to do.
    https://www.tacomaworld.com/threads/diy-basic-speaker-upgrade-2nd-gen-access-cab.3198/
    ChemDawg likes this.
  4. Mar 17, 2017 at 11:55 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    Yikes. Doesn't sound fun or cheap. Thanks for the replies!
  5. Mar 18, 2017 at 3:34 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Same thing happened to me last year. Had to replace top hinge and the door check/limiter. Take off the door panel to see what's interfering with window travel.. probably nothing broken, should be easy to bend stuff out of the way.
  6. Mar 18, 2017 at 3:37 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I third taking the panel off just to take a look. Should be able to find out what the issue is. Might be able to fix it yourself.
  7. Mar 18, 2017 at 5:21 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sounds like the door checker is toasted too. That's usually what makes a popping sound when damaged
    outlawtacoma likes this.
  8. Feb 7, 2019 at 5:47 PM
    drewbert41
    drewbert41 Well-Known Member
    Champaign, IL
    21 Cement DCSB 4x4 TRD OR
    Had this happen to me tonight. It is pretty shitty but at least it didn't get a huge dent from the quarter panel. that was my fear.
    I had the door checker loose recently because i temporarily grounded something to it for testing. Guess I should take it off and check it out/retighten. I will pull off the door panel too and look at the window track and see if I can see anything. Hope my hinge isn't messed up.
    There was a little resistance at first but no pop. My window goes down a little over half way before it starts to get stuck. Can't afford to force it and get it off the track in this weather.
