Wind Noise, access cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rehabber, Jan 24, 2007.
  1. Apr 20, 2007 at 5:29 AM
    evolution6972
    evolution6972 Well-Known Member
    thats interesting cause when i use my ac with the fan blowing from outside in i noticed when someone got out my truck i felt like i was in an airplane i felt the pressure drop and i had to pop my ears mine must be stuffed already
  2. Oct 15, 2007 at 6:58 PM
    cusas6
    cusas6 Member
    Steve,
    Did you ever get a fix for your wind noise? I get a intermittent whine/buzz when I am cruising along the highway and get a good crosswind. I saw ldytaco's recommendation, but I'm not sure where she is talking about putting the tape. I took it to the dealer and they said that they couldn't reproduce the issue.
    -Scott
  3. Oct 15, 2007 at 7:21 PM
    evolution6972
    never did fix it just ignored it and havent traveled that much in a long time but it is these heat sheilds that vibrate and make noise they look like foil pans attached to the truck
  4. Oct 15, 2007 at 8:46 PM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Really? Cool. Do I have an escape pod too? :D
  5. Oct 24, 2007 at 4:55 AM
    kaisersteiner
    kaisersteiner Active Member
    I have had that noise too with the a/c on. I thought my tires or something was rubbing. Then I thought maybe it was the step bars getting wind turbulance. Sounds like it comes from the center of the cab underneath. My fix was to turn up the radio.
  6. Oct 24, 2007 at 5:41 AM
    GTiVR6r
    GTiVR6r Big Cat Chew Toy
    Carpentersville, IL
    07 Tacoma Access Cab 2.7L Impulse Red
    I experience a hollow drone kinda noise I isolated to the exterior mirrors.
    The plastic mirror bodys just resonate at certain speeds due to wind turbulence.
    Fix - Remove exterior mirrors or turn up the stereo.
    Experiencing a wind noise coming from the back of the access cab.
    Seems to be the bed is "just" slightly wider than the cab and the leading edge is wedge shaped which the wind catches in that air space and makes noise over 70. (Rangers and Mazdas this area is flat to the cab, no such wind noises.)
    Fix - Ignore it and/or turn up the stereo.
    Drivers & passenger doors and access doors various rattles.
    Cause, belt buckle hitting access door and lowest anchor point of belt rattles if belt is worn too slack. Metal on metal sounding rattle.
    Fix - Fuzzy Velcro on belt bump stop on doors. Could also add some Velcro to unused buckles and secure to doors when not in use. (VWs have belt clips for this exact reason.) Lower belt anchor point rattles - pull the belt tighter around you.
    - M
  7. Oct 24, 2007 at 8:43 AM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    I already told you guys how to fix the noise from the rear of the cab.
  8. Oct 24, 2007 at 9:38 AM
    GTiVR6r
    Carpentersville, IL
    Do you have to remove anything to gain access to the vent?
  9. Oct 27, 2007 at 3:57 PM
    MATTRESS
    MATTRESS Member
    LONG BEACH, CA
    TRD SPORT ACCESS CAB 4x4 BLACK SAND PEARL
    DEFLAPPED, FLOWMASTER 40 SERIES TURN-DOWN BEFORE AXEL, VOLANT COLD AIR INTAKE, TRD FLOOR MATS AND SEAT COVERS.....THERES MORE TO COME, ITS EARLY.
    Well I have a 2008 TRD sport with no external mods and I have had NO problems with AERO noise's of any kind at freeway speeds.....maybe they fixed it on the 08...?
  10. Nov 7, 2007 at 4:58 AM
    ZonKs
    ZonKs Can speak french in Russian.
    Glendale, CA
    =p
    Ive had my truck since May 2007. There has been absolutely zero wind noise until last night when I was driving on the freeway at around 75 mph. It seemed to be coming from the front of the cab. I couldnt isolate it any further to this point. Sometimes it sounded like it was coming from the drivers side mirror, and at other times it sounded like it was coming from the passenger side. I just put on a shorty antenna, but I doubt this is the cause:confused: Yeah, its real annoying. Im real picky about those types of things.
  11. Nov 24, 2007 at 6:57 PM
    79cruiserfj40
    79cruiserfj40 Active Member
    Arkansas
    07 Tacoma Double Cab TRD Sport 4x4
    I have the same noise from the windshield area of my 05 Tacoma Dbl Cab. My brother-in-law's 05 access cab did the same thing. It seems to happen with strong crosswinds. I am trying to pinpoint the exact location of where the noise is so that I can fix it... so far, it seems like the noise is above the rear view mirror.
    If you figure anything out or have any ideas, PLEASE let me know. It is very annoying when it sporadically makes that noise.
  12. Nov 24, 2007 at 7:37 PM
    Bigman_CP
    Bigman_CP Member
    Southern Illinois
    07 TRD Sport 4x4
    3" lift, tires, clear altezza tail lights; clear turn signal lights; vent visors; K&N air filter; all emblems removed; LED lic plate, reverse, dome, and map lights;
    I have that same problem on my 07. I usually only hear it at about 70 mph and at times when I pass a semi truck.
  13. Nov 24, 2007 at 7:43 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    my 06 has a little aero noise, the severity changes depending on what the direction it hits the truck. :eek:
  14. Jan 6, 2008 at 2:16 PM
    Papaken
    Papaken Member
    Meredith, NH
    08 Tacoma, V6 4.0L, 4x4 6spd, Access Cab, 16" BFG Rugged Trail T/A , TRD, SR5, Off-Rd & Towing Pkgs
    I've had my 08 Access Cab, TRD over 50mph with no problems yet. Hopefully they've finally caught this in production.
    I have plans next weekend to go a bit faster, and will let all know.
    Thanks in advance for all the tips though!
    Cya,
    Papaken
    [yes I will come up with an avatar and sig,,,,lol]
  15. Jan 6, 2008 at 6:51 PM
    #35
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    SILVER 08 TACOMA DC LB 4X4 TRD Sprt Pkg, Side
    Well... do not wait, tomorrow Monday, January 7, I will deliver my 08 DC 4x4 TRD Sport truck to the only local toyota dealer at Laredo for several reasons (Rear spring TSB, Tailgate TSB) and one of them is a front driver's side wind sound, this noticable at 40MPH and on even more on crossed winds. You are not alone, I do have a LEER CAP and over it a Roof Safari Rack, but this happened even before all these mods.
    Let see what happens I let you informed.
    Regards.
  16. Jan 9, 2008 at 6:09 PM
    #36
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Now I don't know about any of you but have you ever gotten out of your truck with the air on high, shut the door and notice how much air blows out the lock in the door where you put your key?...Is it just me or has anyone else noticed this?..I tried it on my 2000 prerunner and no air!..In fact, my 2000 is like a lincoln town car compared to my 2005 prerunner!
  17. Mar 13, 2008 at 3:03 PM
    #37
    majoro
    majoro New Member
    07 Tacoma TRD Sport
    I’ve temporarily fixed my whistling/kazoo noise with by applying a black electrical tape to the rubber windshield seal at the top of the windshield all of the way across. It’s hardly noticeable, and it’s lasted since Halloween. I hope to get my TRD to the dealer soon, but until then, this seems to work. Depending on the wind direction, the kazoo noise would sometimes kick in below hiway speeds, but I’ll guarantee I could make it whistle at non-legal speeds. After reading many postings with different hypothesis, to include the TSB from ‘05, I started taping different parts of my windshield during a long trip until the noise stopped. Electrical tape is much cheaper than the gas/time to drive to my dealer.
  18. Mar 14, 2008 at 1:07 PM
    #38
    khfactor
    khfactor Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger
    I, too have experienced this also. Especially in the morning when you first start the truck when the engine really roars (rough idle), you can feel the cold air escaping thru the crack next to the key hole. I discovered that it was NOT the keyhole, but from the gap between the actual door handle part that you pull out and the stationary door handle part.
    I meant to bring it to the dealership's attention, but keep forgetting... Anyone figured out how to correct this??? :(
  19. Mar 14, 2008 at 1:47 PM
    #39
    JGUT
    JGUT Well-Known Member
    Yuma, AZ
    08 PreRunner Off Road Package
    2 Kicker 8" SL5, Kicker 750.1 mono amp, Kicker 200.4 amp, Kicker 6x9's front, Kicker 6.5's Rear, Pioneer AVH-P3200BT, Rear view camera
    My 2008 Double Cab has wind noise starting at 35 to 40 mph on the driver's window. I just turn up the radio but I will tell the dealer on my first oil change coming up in less than 1,000 miles.
  20. Mar 16, 2008 at 1:14 PM
    #40
    Papaken
    Papaken Member
    Meredith, NH
    So far , no problem with any noises. Had her up around 70mph for half an hour.
    Holding out hope for the 08's Access Cabs.
