Wind noise found - lets fix it!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Strech, Dec 13, 2015.
  1. Dec 13, 2015 at 3:02 PM
    calawahsteelie
    calawahsteelie Active Member
    PNW
    2016 DCSB OR 4x4
    The only time that I get the whistling or howling is in a cross wind. It sounds to me like it's coming from the drivers side mirror. I wonder if has anything to do with those fins that they put on the mirrors? I got a pretty good video on my phone that I'll show the dealer when I take it in.
  2. Dec 13, 2015 at 3:09 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    We all tried that...That was the easiest thing to eliminate.
  3. Dec 13, 2015 at 3:09 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
  4. Dec 13, 2015 at 3:18 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    don,t want to be a smart ass, but you got a part # for that fix.
  5. Dec 13, 2015 at 3:28 PM
    MudsweatNgearz
    MudsweatNgearz Well-Known Member
    Arizona
    2016 DCSB TRD Sport Inferno & 2005 Sport DCLB 4X4 White
    Ghetto gasket?
    CusterFan likes this.
  6. Dec 13, 2015 at 4:02 PM
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    Same here, I had 1500 miles on my Tacoma before I heard it for the first time and only a couple times since.
  7. Dec 13, 2015 at 4:11 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Why bring your particular problem into an unrelated thread then?
    16tacomaOR and T4RFTMFW like this.
  8. Dec 13, 2015 at 4:15 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Fill it up with silicone or try a seal weld.
  9. Dec 13, 2015 at 4:16 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I live up in the mountains the winds blows out of the NW some times up to 60 mph. sitting dead still my truck will howl right behind the rear access door in the wind. There is a pocket behind the rear lower door edge I can block it with my hand and the noise goes away it is a source of noise I can't say it is what people are hearing but I know it's there.
    Old one and 3dBdown like this.
  10. Dec 13, 2015 at 4:16 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    im going to put some small clamps to that vertical rubber piece between the bed
    and cab to see if it does anything. it might change to a higher pitch. lol
  11. Dec 13, 2015 at 4:26 PM
    Qwack
    Oahu
    ok forget the small clamps, they don't fit well. I found some dark grey water heater
    pipe insulating foam from home depot. they are stealth and fit great. going for a test
    drive soon. hopefully this helps.
  12. Dec 13, 2015 at 4:45 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Sound can resonate, reflect and bounce off of the metal, that's what makes it hard to find and fix...
    Toyota use to be the best at this...
    It was strange that dyno matting my roof reduced 90% of the wind noise I thought was coming from the a pillar....
    Added bonus, I'll take it....
    But reduce wind noise, now I can hear other stuff.... Next project????
    Dyno matt behind the rear seats might help with the howl??????
    Good luck guys.........
  13. Dec 13, 2015 at 4:50 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Probably where my highway noise comes from.
  14. Dec 13, 2015 at 4:56 PM
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    The black pipe insulation will most likely work perfectly. However, my guess is that the wind is whistling through there at one specific point. IE.. the sides, the top or the bottom. So, if you test these individually you may find that you don't have to stuff that insulation everywere.
  15. Dec 13, 2015 at 4:59 PM
    #35
    CusterFan
    I think it from the bed sitting so close to the back of the cab.
  16. Dec 13, 2015 at 4:59 PM
    #36
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    What I hear is clearly aero (as wind buffets affect it) at 35-45 mph all the time. Today I was in a good headwind and it was kicking in at 20-30 mph and wasn't kicking in on the way back (tailwind). It always sounds like the mirror area, but nothing that I do affects it. I have slowly been working my way back taping holes etc., but what you are describing sounds like a good possible culprit. I knew if somebody had good wind outside the vehicle, that it would uncover itself. It has become a minor challenge for me, but the sound really doesn't bother me.
    Would you mind taking a pic of the particular spot.
  17. Dec 13, 2015 at 5:07 PM
    #37
    TacoBella
    Tom
    Every noise related thread will be read with interest by those with open service tickets.
    ESPECIALLY one that claims "it's found"
    This one is a non starter. Those of us dealing the howling noise that is constant and never goes away between 35-45MPH will see this thread is of no help and move on..
  18. Dec 13, 2015 at 5:19 PM
    #38
    3dBdown
    It clearly says "WIND NOISE" in the thread title, so what it is claiming as "found" should be of no interest to those with a mechanical problem.
    Tunngavik likes this.
  19. Dec 13, 2015 at 5:28 PM
    #39
    TacoBella
    Tom
    The OP mentions a "howl" not just wind noise......The howl is what we have constantly. Without regard to outside conditions.
    We only recently were told it looks like it may be mechanical because nothing changes it. Wind direction, following close, cross winds. The noise is constant and does not alter with conditions.
    There is no definite answer but they are now leaning in the mechanical direction, Found This out two days ago. There are a handful of us working on this along with dealing with Toyota engineers and Regional techs So naturally any noise thread will be looked at.
    I would say of all the "issues" presented this one is getting the most attention from Toyota because there are a lot of us who banded together and opened tickets and are working closely with our dealer's Service Managers. Who knows how many non forum members have brought this up with their dealers. I am guessing because of the prominence of the noise, a few,
    Toyota has finally recognized it's a problem. That was our first hurdle. We were being told this was a "characteristic of the truck" Now that they have concluded it's not normal, they will find the solution. People need to know which noise is the one we are working on.
    Suxdsmdmr likes this.
  20. Dec 13, 2015 at 5:32 PM
    #40
    splitbolt
    NW Arkansas
    I didn't know if you were being altruistic or not. Thanks for setting the record straight.
    All your posts of unsubstantiated mechanical noises only serves to confuse those who might not share your plight.
    You're desperate for a solution and deliberately obfuscate all noise threads with your recruitment efforts.
    This thread is people with real world solutions to their real world problems.
