Wind Noise-Not Kazoo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cheapo38, Aug 30, 2017.
  1. Sep 7, 2017 at 10:59 AM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I actually noticed this Tuesday while driving to work. My passenger had shut both vents on their side, unbeknownst to me, and I was blown away with how badly the wind noise inside the cab was. I realized both vents were closed, at which point I opened up the one that I could reach and turned the fan down from 3 to 2 and the noise reduced by probably 70-80%.
  2. Sep 7, 2017 at 1:09 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I had a slight whistle at 60 on the driver side. Dealer reset the door and window trim...resolved.
  3. Sep 12, 2017 at 9:56 AM
    Khakiman
    Khakiman Well-Known Member
    2017 Black Tacoma 4X4 Double Cab TRD Sport
    Front Grille, Step Bars, Tinted Windows, Tonneau Cover, Wheels, Tires, Roof Racks, Mud Flaps, Led Fog Lights, Mob Armor Phone Mount, Console Organizer, Pioneer AVIC 8200 NEX Radio/GPS,
    I have the same noise at around 50-65mph. Thought it was the factory roof rack but now not so sure. It's beginning to get annoying.
  4. Oct 4, 2017 at 10:37 AM
    WetGunPowder
    WetGunPowder New Member
    Boyd
    2017 Tacoma Access Cab Off Road
    Another name to add to the list. My dealer says it's because the box is narrower than the cab???? They realize it is a problem but have no f-in clue what to do to fix it.
  5. Oct 4, 2017 at 11:10 AM
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    I've noticed that if my driver left dash vent is slightly closed, I can get a wind noise from that area. To me, it sounds like i left the window cracked a bit. If I open the vent up, the sound disappears immediately. I typically notice it on a on ramp when I get above 50 mph, anytime before that and I never notice it.
    I noticed that as my speed increases, the amount of air coming through the vent increases even if the fan setting is set the same. It has to be vent turbulence issue when its partially closed.
  6. Oct 4, 2017 at 11:27 AM
    SAND$$$
    SAND$$$ Well-Known Member
    Jovin
    Burbank
    2017 Quick Sand Tacoma
    I have this issue too. It only happens when I'm on the freeway going above 60+. It feels like my driver side window is slightly open and creates a hissing sound. I've looked at the trims around both driver side windows and I've noticed it being a little loose and I've pressed down along the window pane but it's still making the same noise. If it continues to happen I'm sending it to the dealer.
  7. Oct 4, 2017 at 11:28 AM
    DPT852
    DPT852 Well-Known Member
    Dan
    Connecticut
    2017 BR TRDOR
    I had a similar noise to this that I only noticed on my first long road trip in the truck. It was coming from both F/L and F/R doors, and sounded very similar to someone crinkling a plastic grocery bag by my ear. Definitely wind noise, but at the time I was not sure if it was coming from the window, door, or roof.
    After playing around with the windows and rolling them down and then all the way back up it did not seem to make any difference at all. After about 30 mins of listening to this and thinking about what it could be from (I assumed it was due to some kind of cavitation or air flow disruption caused by my window visors) I decided to ever so slightly roll down the offending windows by pecking at the button.
    Sure enough, rolling the window down the slightest amount I possibly could caused the sound to stop on both sides. Not really "opening" the window, just moving the glass down maybe 1/8th of an inch was enough to either complete the seal or take pressure off of something. Didn't notice the HVAC having any influence on the noise but I really didn't think that was a possible culprit at the time.
  8. Oct 4, 2017 at 12:36 PM
    WetGunPowder
    Boyd
    I'm thinking a mass telephone blitz to the Toyota Customer Experience phone line might be in order.....
    (800) 331-4331
