Wind noise problem
Discussion in '4 Cylinder' started by JOSELITE, Nov 29, 2009.
  1. Nov 29, 2009 at 7:21 PM
    JOSELITE
    JOSELITE [OP] Member
    Deep South Texas by the Mexican border & South Pad
    2 door
    front mud flaps tow hitch
    TACO ACCESS CAB 2009 HAS A WIND NOISE PROBLEM
    ANY IDEAS ON HOW TO CORRECT IT
    :infantry:
  2. Nov 29, 2009 at 7:24 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    It's pretty loud in my truck to at highway speeds. I don't think it's a problem.
    There is a guy on here that put some sort of extra seal between the doors and the door jam and that reduced it.
  3. Dec 6, 2009 at 7:27 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    You might try lubricating all of your door seals with silicone. I use a product that's supposed to be a "tire shine". It's almost pure liquid silicone.
    All neoprene seals tend to become stiff with time, especially in hot, dry climates. I think Texas qualifies.
    While you're cleaning and greasing the seals with silicone, make sure that whatever door frame they contact is clean. Mud jammed here and there can cause some neat sounds.
    If these maintenance tricks don't work, a good body shop can check door alignment and fit. Their initial check will be to drag a dollar bill along each seal with the door closed. There should be light drag on the bill. If it "slips" at any point, the seal is poor, causing noise.
    That's just to start. There are many sources of noise on any vehicle. Good luck!
  4. Dec 7, 2009 at 2:34 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    at least you don't have a reg cab.
    don't even get me started on wind and road noise...
  5. Dec 7, 2009 at 6:59 AM
    JOSELITE
    2 door
    Thank you all that have submiitted a solution to the wind noise problem
  6. Dec 7, 2009 at 7:06 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if its from the windshield i think there is a TSB to fix it. I get noise from mine, i need to get it replaced.
  7. Dec 7, 2009 at 7:19 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    The first time I herd that wind noise i thought it was my font end. I buckled up right away thinking my front end was going to fall off. And mine is very loud i could have my music on 50 and can still hear it.
  8. Dec 23, 2009 at 6:20 PM
    Yota1
    Yota1 Well-Known Member
    i find these trucks to lack insulation. road noise is crazy, even just closingthedooor. Thhhinnn! really needs some insulation. i also hear a far anoumt of road noise as well, but not a wind noise.
    I have found though that with the access cab, if the back door is not fully close, and i try and close the front door, the seal is not tight at all.
