Wind noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chao$, Aug 2, 2016.
  1. Dec 3, 2016 at 9:56 PM
    #41
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    It's such a majestic sound. Leave it.
  2. Dec 3, 2016 at 10:02 PM
    #42
    Sparky2
    Sparky2 Well-Known Member
    Keith
    2016 Tacoma TRD
    Same here...
    I'm going to try adding some sticky foam insulation right about where I'm squeezing in the video.
  3. Dec 3, 2016 at 10:08 PM
    #43
    Howanic
    Howanic Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    I have been told that Toyota is coming out with thicker door seals. High winds make the current rubber flap very rapidly at certain cross winds.
    No idea when the TSB will be coming out.
  4. Dec 4, 2016 at 2:16 AM
    #44
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
    I'm pretty sure I'm hearing this on my 17. Will def' let the dealer know at the first service. For now I' might try stuffing something in between the weather stripe to fill in the dead space.
  5. Dec 4, 2016 at 6:44 AM
    #45
    globitron
    globitron Active Member
    Colorado
    2017 TRD OR
    I went to the dealer - they heard it and told me there was a window seal TSB coming out, and would contact me in the future... no idea how long it will be but it is super annoying.
    I have a high pitch wind noise above 35 MPH and the other sound when the wind is blowing sideways.
  6. Dec 4, 2016 at 7:33 AM
    #46
    Sparky2
    Keith
    2016 Tacoma TRD
    As a "for now solution", if you guys haven't noticed...
    Run the fresh air vent open. This pretty much makes the noise go away. I know it's getting cold out, but mix some heat in there and leave it open to shut it up.
    Then... When Toyota either replaces the seals (or comes up with a bandaid solution like stuffing the seal), we can use whatever mode.
  7. Dec 4, 2016 at 1:50 PM
    #47
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    I am actually unaware of this said solution? I honestly have to ask how to achieve this when it's happening so I can test it. I have had this issue since day 1 and it likely explains why I have it some days vs others because I have hvac system set a certain way.
    The dealership thinks I am crazy because I can't replicate it the couples of times it's been there, regardless of the sound clips I have recorded.
    Perhaps this is why, the tech is switching the hvac on when he gets in it to something he likes and this won't allow him (or her) to experience it.
  8. Dec 4, 2016 at 1:57 PM
    #48
    Sparky2
    Keith
    2016 Tacoma TRD
    It's the recirculate button in the AC controls. Looks like a truck with a circular arrow on it.
    Make sure the light is off and the noise will reduce or even stop.
    Has worked on 2 tacos "for now"... YMMV.
    Taco Fan and Wraith600[QUOTED] like this.
  9. Dec 4, 2016 at 1:58 PM
    #49
    Wraith600
    Thank you!
  10. Dec 4, 2016 at 3:01 PM
    #50
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I had the LCA TSB performed and it reduced 'one' of the high-speed howls.
    The remaining howl I believe, is the driver door seal that needs to be replaced. The passenger door seal doesn't appear to make any noise, but perhaps that is because I rarely have a passenger use that door and the seals there might still be OK.
    I downloaded a few of the videos above to play for my dealer - many thanks!
  11. Dec 4, 2016 at 3:09 PM
    #51
    Wraith600
    I find it interesting that it's only the drivers side seal being reported when in theory they should be of the exact same design. Describe it as a whistle and not a howl, it's really so different pitches.
  12. Dec 4, 2016 at 3:27 PM
    #52
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Mine is passenger side only
  13. Dec 4, 2016 at 3:36 PM
    #53
    Sparky2
    Keith
    2016 Tacoma TRD
    Mine is mostly the driver's side, but both do it depending on the crosswind.
  14. Dec 4, 2016 at 3:54 PM
    #54
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My rear end howls...the truck has noise issues
    stealthmode and mateo_roberto like this.
  15. Dec 4, 2016 at 5:15 PM
    #55
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    How often do you have a passenger in the truck?
    How often do you have a driver in the truck?
    Physical distance may explain a good chunk of that.
  16. Dec 4, 2016 at 8:10 PM
    #56
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    Me too. Where I live we have 90+kmh winds from the west a lot of days and it's only heading west and north it does it..
    I'm so happy it's my truck and not my prinsu rack.. Lol stupid to say.
  17. Dec 4, 2016 at 8:33 PM
    #57
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Exact same noise, exact same issue since 2005. My truck had it before, fixed with TSB.
    Issue now carried over to the "all new" third gen.... :facepalm:
    mateo_roberto and smitty99 like this.
  18. Dec 5, 2016 at 1:04 AM
    #58
    Sleevez
    LA / Toronto
    Mines in the driver side only so far, but it only got 900miles on it. Will def try the vent trick though.
  19. Dec 5, 2016 at 3:21 PM
    #59
    Wraith600
    You would think that...however, my started very quickly and I thought perhaps the same thing, but at this point they both should be doing it.
  20. Dec 5, 2016 at 3:46 PM
    #60
    rz2mbc
    rz2mbc Well-Known Member
    Exactly what I had on my 2016 Limited on the drivers side. Took it to the dealer and they changed the door seal. Fixed the issue. The only wind noise now is when I blow a fart !!
    LEXICON likes this.
