Wind Whistling Noise (with Video!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kamdawg, Jul 11, 2013.
  1. Feb 8, 2014 at 9:08 AM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    I used this SAME video and showed it to the SA and the Tech, I also recorded one myself as well. Showed that to them too. The SA said it happened on his '11 too and he took out the antenna and it went away---no can do here since I listen to radios.
    They both want to "take a ride and see" but there is NO WINDS so that is NO can do neither.
    I went home disappointed because they have no idea what is wrong.
  2. Mar 11, 2014 at 7:48 AM
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    I have a 2011 TRD and the noise mine makes on the highway when I reach 70mpg + is so loud that Its hard to hear my radio..
  3. Mar 11, 2014 at 10:16 AM
    sattwood3590
    sattwood3590 Member
    '13 PreRunner
    I have the same thing on my '13 dbl cab long bed. Also took to dealer (Roseville Toyota) and they did nothing. Very poor customer service.
  4. Mar 11, 2014 at 2:01 PM
    Hiker
    Hiker Well-Known Member
    HotZona
    My whistle went away after I installed a bug shield. I only get it know when I'm close to 100mph.
  5. Mar 12, 2014 at 4:58 AM
    VinTaco
    Burnaby bc
    Well I would take it in to another dealer because I called a dealer yesterday and they are very aware of the issue so they set up an appointment for mine to fix it. Toyota is also aware of the problem but I guess they just don't have enough complaints yet to do a recall..
  6. Mar 12, 2014 at 5:00 AM
    VinTaco
    Burnaby bc
    Trust me its NOT the antenna, its the trim around the windshield and it is a warranty issue if yours is still under warranty.. What is happening is the trim around the windshield starts to vibrate against the windshield at higher speeds, that is what I was told from the service dept. and they have fix a few already.
  7. Apr 13, 2014 at 5:21 PM
    TacomaTx13
    TacomaTx13 Member
    Texas
    2013 Tacoma 4X4
    Update - this was happening again and I got the Service Manager on the phone while it was happening. Took it down to the dealership and they had an employee that knew what was causing the problem. They did not replace the windshield but they re-glued the window gaskets and it seems to be working.
  8. Oct 20, 2014 at 4:02 AM
    Briwaz
    Briwaz Member
    PA
    '14 Metallic Gray TRD Sport
    N-Fab Nerf Bar Steps Extang Tonneau Cover Weather Tech vent shades Weather Tech mats
    Has anyone found a confirmed solution to this issue yet? This thread, and others, seem to suggest either an issue with the seal on the windshield, seal on the passenger door, the antenna, or the seal on the mirrors. Some good suggestions, but they seem all over the place?
    Here is a link to the noise my car is making - sounds identical to the noises every one else is having!
    https://www.youtube.com/watch?v=nD7Rge6qGss&list=UUctvGumnuG-53VS1lIGIWeg
  9. Oct 21, 2014 at 4:08 AM
    VinTaco
    Burnaby bc
    Cant believe it is still happening, Toyota is not too worried about it because they feel its not a safety issue. I had mine fixed by a auto glass replacement company, they didn't even charge me, it took all of 2 minutes to fix. Its the rubber trim at the top of the windshield where it meets the roof, they just ran a bead of window caulking between the rubber trim and the roof and the noise is gone.
  10. Oct 21, 2014 at 6:55 AM
    TacomaTC
    TacomaTC Active Member
    Tom
    DFW
    13 DCLB
    on my 2013, this noise was from the door jam seal.
    http://www.tacomaworld.com/forum/2n...istling-noise-crosswinds-highway-speed-3.html
  11. Oct 21, 2014 at 3:48 PM
    TacomaTx13
    TacomaTx13 Member
    Texas
    2013 Tacoma 4X4
    So far this has been repaired. The dealership maybe put a bandage on it, but they resealed the windshield and haven't had the noise again. Still have the window noise and they finally said there was noise and they replaced the gasket. That didn't help!
    Anyone have any fixes for the window?
  12. Oct 21, 2014 at 6:59 PM
    Longbow3
    Longbow3 Well-Known Member
    Henry
    North Central, TX
    Barcelona Red Limited 4x4
    Tri fold soft bedcover
    I get the same noise with a strong cross wind. I get it from both sides, depending on the direction of the wind. It sounds like the noise is coming from the front of the hood on the upwind side. I believe it's the gap seal along the front of the hood.
  13. Nov 8, 2014 at 4:40 AM
    Briwaz
    Briwaz Member
    PA
    Since I had no luck getting this issue addressed by my dealer, I contacted Toyota Corporate directly. This is the lovely response that I received (personal info redacted). They confirm this issue is well known with the Tacoma and there is no action planned to address it.
    Fri, Nov 7, 2014 at 4:48 PM
    Dear Mr. ________,
    Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
    We apologize for your concern with windnoise in your 2014 Tacoma.
    At this time, the windnoise is considered a characteristic of the Tacoma. Until Toyota releases a bulletin, there are no repairs available at this time for Team Toyota to make.
    We recommend that you check with your dealer at your service intervals to see if Toyota has released a bulletin or update for the windnoise.
    Your email has been documented at our National Headquarters under file #____________. If we can be of further assistance, please feel free to contact us.
    Sincerely,
    Kym W.
    Toyota Customer Experience
  14. Nov 8, 2014 at 12:36 PM
    RyanS
    RyanS Active Member
    Nc
    13 prerunner sr5
    I have the same noises, spoke to the dealer about it and was told it's normal, they did ask what year truck I had though. Anyone had any luck with dealers around the greater Charlotte, Nc area?
  15. Nov 9, 2014 at 5:32 AM
    #35
    VinTaco
    Burnaby bc
    I guess things must be different with dealers down there, up here in Vancouver the dealers DO address the problem...
  16. Nov 9, 2014 at 6:13 AM
    #36
    kg5ie
    kg5ie Well-Known Member
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    My 2014 did it on the way home from the dealership the day I picked it up.
    :mad:
  17. Nov 9, 2014 at 2:58 PM
    #37
    jhuggans
    jhuggans Member
    Warrensburg, MO
    2010 ACL 4x4 2.7
    If it makes you feel better, my 2015 did this yesterday :) ....I bought it exactly 1 week ago.
  18. Nov 12, 2014 at 7:22 AM
    #38
    Longbow3
    Henry
    North Central, TX
    with the strong wind we've been having here lately, I have been getting the noise quite often. I finally figured out where it was coming from. It is the driver and front passenger side windows. When the noise happens I can push on the window along the front edge near the track seal and the noise gets muted. I'm going to investigate how to tighten up the window track seal to see if I can stop this annoyance.
  19. Nov 13, 2014 at 7:07 AM
    #39
    TacomaTC
    Tom
    DFW
    13 DCLB
    Its the soft door seals. Tape one of the doors closed with electrical tape to test it out. We should have enough wind through today in TX to easily reproduce this. Run a single strip tape from the fender all along the top seam of the door covering the soft seal between the door and cab.
    I took my truck into the dealer with the passenger door taped shut and asked them if that was cool.... LOL They finally replaced the passenger door seal last year once I was able to find the root cause. They replace the driver side last month after it started making the noise this past summer. I no longer have the noise in the video above..
    Don't get me wrong, the truck still whistles like nobody's business, but the vibrating nastiness is gone.
  20. Dec 1, 2014 at 7:33 AM
    #40
    Dr2
    Dr2 Member
    2014 tacoma dc
    I also have a 2014 short bed Tacoma that whistles in the wind above 70 mph. It matches the two videos posted. If you pull in on the A frame section of the door frame metal portion from the interior the noise goes away. This happens on both the DS and PS doors. With the windshield TSB this is not applicable to the 2014 within AllData, usually when issued they address future models. Has anyone tried rolling the door windows down and applying pressure to the A frame portion of the door to bend it inward and improve the sealing of the weather stripping?
