Window control rattle!!! Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dawhitetacoma, Jan 10, 2014.
  1. Jan 10, 2014 at 6:09 AM
    dawhitetacoma
    dawhitetacoma [OP] Active Member
    So I picked up my 13 double cab tacoma a few weeks back and love it so far. There is only one gripe I have. The window controls on the drivers side rattles with certain bass. I pulled it out and played with it to no avail. I have looked at a lot of posts about this, but has anyone actually fixed it and how. I seem to fixate on that dang rattle everytime I drive and listen to the radio!
  2. Jan 10, 2014 at 7:07 AM
    dawhitetacoma
    I forgot to mention that the rattle stops when i apply any pressure to the control, like resting my knee against it.
  3. Jan 10, 2014 at 7:13 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    It might have not been pushed all the way down. Take it out and put it back in. Use a plastic panel remover tool.
  4. Jan 10, 2014 at 7:15 AM
    dawhitetacoma
    i was able to get it out just fine and it went all the way back in..
  5. Jan 10, 2014 at 7:22 AM
    jw1983
    Alberta
    So it fixed the rattle?
  6. Jan 10, 2014 at 7:30 AM
    dawhitetacoma
    nope its still there.. =/
  7. Jan 10, 2014 at 7:37 AM
    jw1983
    Alberta
    Do you have aftermarket speakers?
  8. Jan 10, 2014 at 7:46 AM
    VolFan57
    VolFan57 Well-Known Member
    TENNESSEE
    2016 TRD OR 4x4 - MGM - traded. 2018 TRD Sport BRM 6MT
    Bump. I have the same issue and its annoying.
  9. Jan 10, 2014 at 7:47 AM
    dawhitetacoma
  10. Jan 10, 2014 at 8:05 AM
    dawhitetacoma
    I'm trying to fix it. I can't live with it lol!
  11. Jan 10, 2014 at 8:14 AM
    OKTaco4x4
    OKTaco4x4 Member
    Edmond, OK
    4X4 TSS
    Weather Tech Mats, Tinted Windows/visor tent
    Mine has the same issue. Took it to the dealer and they wrapped insulating tape on the driver's door master switches and put it back together.
    Rattle came back 2 weeks later...
  12. Jan 10, 2014 at 8:22 AM
    dawhitetacoma
    I know that's why I'm hesitant to bring it in. I would waste a lot of time and never get it fixed...
  13. Mar 6, 2014 at 10:14 AM
    tears5150
    tears5150 Member
    Pete
    Danville
    '08 Tacoma PreRunner Sport
    2.5" Icon Suspension Lift KC light bar/lights Demello Offroad sliders Demello Offroad High Lift Jack Bed Bar
    So I just read this post and have something very similar going on, but on the passenger side. It gets so annoying that I'll literally lean over while I'm driving to give it a good whack. It works for a few minutes and then comes back. I guess you could say that's a little dangerous. The source is the plastic cover that surrounds the window and lock switches. Apparently the connection points aren't tight enough, which results in the rattle. I tried squirting Shoe Goo along the edges to see if I could get it to stop and that just made a huge mess. I think I'm going to try removing the piece altogether and apply something else before replacing the cover. I'll post again with the results. Wish me luck!
  14. Apr 4, 2014 at 5:40 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Bump for possible fix.
    This sound is driving me nuts.
  15. Apr 4, 2014 at 8:50 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I have a 13 too. I could have swore my rattle was coming from the actually driver side door speaker near the window. Doesnt happen all the time, only when certain low bass chords hit (aka most tool songs!). Wonder if it can be the switch. I've tried holding down every single piece of plastic, either it be on the door switches or the lock, etc, and it doesn't work. The guys at the dealership said they would replace the speaker, but I'm afraid that will open a can of worms by taking apart the door and thus create more squeaks and rattles.
  16. Apr 4, 2014 at 8:59 AM
    ToK
    ToK Member
    Travis
    Saskatchewan
    13 TRD Sport
    I have the same issue with my 13.
    sub'd for the solution
  17. Apr 4, 2014 at 10:26 AM
    oklahomastig
    oklahomastig Well-Known Member
    Oklahoma City, OK
    2013 Tacoma TSS 4x4
    I fixed it on mine by pulling the panel off (It's really easy with a panel puller) and cutting up a foam sponge and placing it around the entire outside of the switch, and then reinstalling it. Works like a charm and no rattle whatsoever.
  18. Apr 4, 2014 at 10:38 AM
    BlackTacoma13
    BlackTacoma13 Well-Known Member
    Nick
    Destin, Florida
    2013 black 4x4 sport double cab
    I have the same issue. free bump
  19. Apr 4, 2014 at 9:58 PM
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    Yep same issue was going to talk to dealer about it at 10,000. If I push the vertical part of the door above the controls it goes away. Anyone have tricks or tips? Or a suggestions for dealer?
  20. Apr 6, 2014 at 4:41 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I pulled the control unit out, and sprayed all the tabs that hold it in place with Armor All.
    It hasn't made a sound since.
    I have no explanation for how or why that worked, but it did.
