Window help
Discussion in '1st Gen. Tacomas (1995-2004)' started by twindad, Jan 23, 2017.
  1. Jan 23, 2017 at 7:24 AM
    twindad
    twindad [OP] Member
    Central Texas
    97 4x4
    I'm replacing the regulator on my 97 tacoma driver's side and one of the brackets that bolts the window onto the regulator is broken (pic below). Can I replace the bracket or do I have to replace the entire window? Where could I find a replacement bracket if can be replaced.
    Window_cfe42c1b766716e538f43615393067fab1e837ef.jpg[/URL]
  2. Jan 23, 2017 at 3:40 PM
    Slickster
    Slickster greentaco
    2002 pre
    i had the same problem a while back and found the brackets at an autoparts store. I replaced both since i had it out.
  3. Jan 23, 2017 at 5:24 PM
    twindad
    twindad [OP] Member
    Central Texas
    97 4x4
    Do you remember where you found them? Went to local store today and they didn't have them. How did you attach them to the glass? Looks like they were originally attached with some kind of epoxy
  4. Jan 23, 2017 at 5:35 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  5. Jan 23, 2017 at 10:25 PM
    inwood customs
    Dave
    I see a ton of options using "toyota tacoma window clips"
    but unsure which ones are 100% match. Id call dealership for a part #
  6. Jan 24, 2017 at 6:27 AM
    twindad
    twindad [OP] Member
    Central Texas
    97 4x4
    Awesome. I guess I wasn't calling them by the correct name. Thanks for your help.
    inwood customs likes this.
  7. Jan 24, 2017 at 10:23 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I had this problem on a '91 Civic (the epoxied plastic tab broke).
    I went down to a picknpull and purchased the entire window glass with intact tab (only one on the Civic).
  8. Jan 24, 2017 at 3:36 PM
    Slickster
    Slickster greentaco
    2002 pre
    got them at o'reilly auto parts and they have universal clips, and got a tube of black silicone to glue them.
  9. Jan 25, 2017 at 8:00 AM
    twindad
    twindad [OP] Member
    Central Texas
    97 4x4
    Thanks for all the help. Finally found them on Amazon.
