Window Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by tablesalt, Mar 30, 2010.
  1. Mar 30, 2010 at 9:52 AM
    tablesalt
    tablesalt [OP] Tacoma Lover
    Riverside, CA
    04 PreRunner, Double Cab TRD V6
    Good ole' Stock. Black.
    Hello everyone,
    So yesterday I went to raise all my windows, when I noticed that my left rear passenger window was not closing. It has done this a couple of times now. I was thinking maybe you guys have some advice.
    tablesalt
  2. Mar 30, 2010 at 9:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Power windows?
  3. Mar 30, 2010 at 12:30 PM
    tablesalt
    Riverside, CA
    yes.
    tablesalt
  4. Mar 30, 2010 at 12:51 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    How did you get it closed? Did you use the switch on that door vs. the master switch?
  5. Mar 30, 2010 at 1:04 PM
    tablesalt
    Riverside, CA
    I used the master switch. But I did try the switch on the passenger door also. I finally got it to close, after switching my truck from the on/off position. That is, I would switch the truck to the off position for a couple of seconds, then I would switch it back on. And then I would try to close the window. It took a couple of times until the window finally closed.
    tablesalt
  6. Mar 31, 2010 at 5:27 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Try closing it with the switch on the door in question and see if you have an issues. If it works everytime, I would suspect your master switch to be going bad.
