Window Limiter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cperalta1, Jun 1, 2019.
  1. Jun 1, 2019 at 4:14 AM
    Cperalta1
    Cperalta1 [OP] Active Member
    WA
    '14 Tacoma TRD Sport L/B
    My ‘14 driver’s side window seems to want to go higher (more closed) than it should. When I close the window, I can feel it trying to push past it’s physical limit (top of door frame?). It causes the inner door panel to bulge out a bit too. Is this normal? Is there some type of electronic or mechanical limiter that tells the window when to stop trying to close? Can it be adjusted?
    I searched but came up empty handed.
  2. Jun 1, 2019 at 4:23 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Normal
  3. Jun 1, 2019 at 4:32 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I would take off the inner door panel just to make sure everything looked alright. Not hard. Search on YouTube "How to remove door panels Toyota Tacoma X-runner Access cab & Double Cab" You can thank me later;):devil:
    https://youtu.be/yjhYKzE_yBg
    Bebop likes this.
  4. Jun 1, 2019 at 6:50 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Normal,
    I have a 2014 and does the same...…….
  5. Jun 1, 2019 at 9:30 AM
    Cperalta1
    WA
    Yeah, I removed my door panel yesterday because the window was rattling. Found a loose bolt, tightened it and checked all others. Rattle is gone but I keep thinking that perhaps too much force is being placed on the mechanism caused the loose hardware. How does the motor know when to stop working???
  6. Jun 1, 2019 at 9:39 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    My motor stops when I let of the button. Both up and down. During the winter when the window is frozen, you don’t want to be pushing the button. It’s not a smart button by any means.
