window randomly went down??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08bluetacoma, Dec 15, 2011.
  1. Dec 15, 2011 at 10:45 AM
    08bluetacoma
    08bluetacoma [OP] Well-Known Member
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    6 inch fabtech alpine stereo flowmaster exhaust
    so i was out driving today (in cold snowy weather) and my driver side window decides its going to roll down and not come back up:mad:.
    anyways about five minutes late of freezing my ass off it decides to go back up:D. But then goes back down... i pulled in my driving way turned the truck off and on a few times and it eventually went back up hoping it decides to stay there because well Canada is cold:canada:
    anyways any thoughts??? electric things are not my forte thats for sure
  2. Dec 15, 2011 at 10:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Could be a regulator issue.
  3. Dec 15, 2011 at 10:46 AM
    08bluetacoma
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    anyway to check it? where is it in the switch?
  4. Dec 15, 2011 at 10:46 AM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Could be some fuse
  5. Dec 15, 2011 at 11:11 AM
    08bluetacoma
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    wouldn't a fuse just cause it not work at all??
  6. Dec 15, 2011 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Not sure how to go about checking the regulator.
  7. Dec 15, 2011 at 11:13 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    A ghost??
  8. Dec 15, 2011 at 12:23 PM
    08bluetacoma
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    thats still what I'm thinking how knows maybe the guy that owned it before me died in it:bananadead:
  9. Dec 15, 2011 at 12:54 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Do you have an after market alarm system?
  10. Dec 15, 2011 at 12:55 PM
    08bluetacoma
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    nope
  11. Dec 15, 2011 at 2:39 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Pound on the door when it decides to do it. Or grab a test lamp, jump the connector with it and let it sit there. It it turns on without pushing the button, then it is either the BCM (button request) or the actual button. If it dosent, then it is a regulator. Sounds like to me, something is jumping somewhere. Possibly rubbed wore grounding itself out or bcm grounding it out.
  12. Dec 15, 2011 at 2:40 PM
    AlaskanTaco
    Anchorage Alaska
  13. Dec 15, 2011 at 2:42 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Bad switch or shorting wire
  14. Dec 15, 2011 at 5:28 PM
    08bluetacoma
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    yah ill have to tear into it tomorrow if its not too cold out
  15. Dec 15, 2011 at 5:30 PM
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    x2
  16. Dec 15, 2011 at 8:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This.
  17. Dec 15, 2011 at 9:00 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    module could be starting to short out also.
  18. Dec 15, 2011 at 9:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d25.pdf
    The only thing that controls the window motor on the driver's door is the switch mounted to the driver's door. And it appears to have electronics in it for the auto down function. I would feel confident ordering a switch to fix the problem. It would be rare for a wiring short to behave this way.
    Regulator (motor and gears) is fine. A bad regulator isn't going to cause spontaneous movement without driver input.
    I don't know what "module" is being referred to above, but the body control module only switches power on and off with the ignition and enables the window switches.
  19. Dec 15, 2011 at 9:09 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Look for one of these :notsure:
  20. Dec 15, 2011 at 9:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Hadn't thought of that.
    Just tell the little guy to play with the passenger side window so you don't freeze you ears off quite so fast.
