window "rattle"
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Nov 9, 2010.
  1. Nov 9, 2010 at 3:46 PM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    my driver side window rattles when i lower it
    are there clips that commonly break on these things?
    what about lubing them up? my passenger side goes up and down fairly slowly
    any links for removing the door panels?
    thanks
  2. Nov 9, 2010 at 3:57 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Mine does the same...Interested to find out what the remedy is.
  3. Nov 9, 2010 at 4:32 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    there is a bolt half way down the door(the part of the door that would be in the door jam) that sometimes come loose on me and when it does i find i makes the window rattle especially when i close the door and the windows down. when i tighten it up the rattle goes away completely. hope this helps
  4. Nov 9, 2010 at 5:38 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    X2 on that fixed mine last week. When you take apart the door their is a clip in top corner closet to the front of the truck. This looks like a button. In the middle of this clip their is a "spike", you must remove the spike bofre you can get the button off. I just broke this clip and ordered a new one from the dealer for a couple of bucks. I don't even know if you can get it out with out destroying it. Oh buy the way this is on a 1997 sorry I don't know what your door looks like.
  5. Nov 10, 2010 at 3:30 PM
    vantaco
    i'll try this tonight
    any more info on taking the door card off to lube up the sliders or anything else?
  6. Nov 10, 2010 at 3:36 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I think in 02 your panel should pop off without needing any new clips or anything. Mine does for 03. But don't take the panel off if you don't need to.
  7. Nov 10, 2010 at 3:36 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Good find. I need to do this.
  8. Nov 10, 2010 at 3:40 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    nice. i noticed my truck was doing the same last week. it would rattle at a certain point when i lower it. im not doin this myself, i'll bring it in for warranty work
  9. Nov 10, 2010 at 3:48 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Haha, it took me 3.73 seconds and 1.5 calories to fix it. A single bolt on the edge of the door.
  10. Nov 10, 2010 at 3:52 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    so you didnt have to pop off your door panel???? mine rattles when the window is completely rolled down...am curious on how i can fix this...
  11. Nov 10, 2010 at 4:16 PM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    Mine only does it when the window is just cracked open, half way down or more... All the way down and up I don't hear it rattle. I'll have to see if the bolt trick works, if not then I'll see about taking the door panel off.
  12. Nov 10, 2010 at 4:56 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Mine rattled only when it was all the way down also. I tightened the bolt on the door and it fixed it. Haven't done anything besides that. If you take the panel off you will have to take off the plastic liner under it and it's still hard to see much under there.
  13. Nov 10, 2010 at 6:44 PM
    YellowDog01
    04 4x4
    Can someone get a picture up here to help me? I looked tonight in the dark but couldnt find it. Might be right in front of my nose...
  14. Nov 10, 2010 at 6:47 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
  15. Nov 10, 2010 at 6:49 PM
    YellowDog01
    04 4x4
    Wow, I was looking in the complete wrong direction. Thanks!
  16. Nov 10, 2010 at 7:09 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    thanks for the info going to def try this out
  17. Nov 10, 2010 at 7:11 PM
    Paseo12
    Paseo12 Well-Known Member
    Bufflalo, NY
    White 03 SR5 TRD off road
    Stock for a little longer
    Anyone have the torque specs for this bolt? Lol
    I always found that squeaking noise to be quite annoying! I will have to do this to mine! Good find thanks yawl!
    Scott
    cryptolime likes this.
  18. Nov 10, 2010 at 7:23 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Ha torque. When it's tight it's good enough. No reason to get out a breaker bar and jump on it.
  19. Nov 10, 2010 at 7:57 PM
    c005jjc
    c005jjc Statistics are boring…until you become one!
    East Tennessee
    01 Prerunner DoubleCab SR5
    Axle wrap mod, Fumoto oil drain valve, Tinted windows
    Well all-right now! I have been troubled with the terrible noise when shutting the door with the window down. I was like others and was about to take the door panel off to see what was lose when I ran across this thread and wa-la!!! Tightened up the bolt and no more rattle when shutting the door with the window down! Sounds like a new truck door shutting. Thanks very much shitroc for the quick and easy fix!!! This is what this site is all about...people sharing knowledge! :)
  20. Nov 10, 2010 at 8:13 PM
    99tacosupreme
    99tacosupreme Well-Known Member
    Kyle
    Southern California
    1999 Black V6 PreRunner TRD
    Pioneer Headunit, Infinity Kappa 6.5" speakers, Alpine Type R sub with Alpine M500 amp, 15% Tint up front 5% in the back, Deckplate mod, Debadged, Bilstien 5100s, Wheelers 1.5"AAL, DDM 55w 6k Lights
    Mine rattles when its about three quarters to half way down but only when its going down. anyone els have this problem, could that loose bolt be my problem?
