window "rattle"
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Nov 9, 2010.
  1. Nov 10, 2010 at 11:46 PM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    ok well definetly dong the tighten bolt thing tomorrow
    what about lubing them up though???
  2. Nov 11, 2010 at 6:51 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Mine must have already been tight, because when I turned the ratchet, the head broke off the bolt :mad: Now I have to take the door panel off, and I don't know how I'm going to get it out
  3. Nov 11, 2010 at 1:42 PM
    vantaco
    tightened mine up, solid as a rock now, thanks guys
  4. Nov 11, 2010 at 3:04 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Just did mine as well. No more window rattle.
  5. Nov 11, 2010 at 4:33 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    glad i could help:D
  6. Nov 11, 2010 at 5:09 PM
    BurritoJimmyFan
    BurritoJimmyFan Well-Known Member
    Frisco, TX
    04 Ext Cab TRD
    Gray Wire Mod, DRL Mod, Deckplate Mod
    I'm going to try this, but mine only rattles if window is up. So, I don't know if it will help. Anyone have a rattle when the window is up?
  7. Nov 11, 2010 at 5:36 PM
    Taco76087
    Robert
    Weatherford,Texas
    That's what mine was, but I broke the head off the bolt.
  8. Nov 11, 2010 at 5:42 PM
    YellowDog01
    04 4x4
    Yep, it really is that easy. I felt really stupid after taking apart my whole panel.
  9. Nov 11, 2010 at 5:52 PM
    eweb84
    eweb84 Member
    Eric
    North Dakota
    03 Double Cab SR5
    It took me a whole 5 seconds to fix this!! That rattle has been bothering me since I bought my truck!! Thanks guys!!
  10. Nov 11, 2010 at 6:17 PM
    vantaco
    ya it's a rather unbelievably easy fix lol
  11. Nov 12, 2010 at 9:16 AM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
  12. Nov 17, 2010 at 5:20 PM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    thought my window was rattling also and got real tired of it so i started tapping the door trying to see what it was. found the bolt, tightened it, good as new!:D
  13. Mar 19, 2011 at 7:08 PM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    My window rattles if it is anything but completely open or completely shut. Annoying as can be. I tightened the bolt that worked for most folks to no avail. Does this sound to everyone else like the window trim that surrounds it is shot? It doesn't look bad and a replacement trim is around $100.
  14. Feb 1, 2013 at 2:27 PM
    mjones
    mjones New Member
    georgia
    2010 double cab pre runner
    None
    Could some one re post a picture of where the bolt is at? My driver window is also rattling, abs I can't seem to find the bolt, 2010 double cab pre runner
  15. Feb 1, 2013 at 3:19 PM
    #35
    mjones
    mjones New Member
    georgia
    None
    I only ask to repist the picture because when I click on any of the previous pictures it says that the picture is no longer in data base.... also it rattles when I let it down a few inches but when its around half way down it didn't rattle anymore, driving me crazy lol
  16. Sep 15, 2013 at 4:54 PM
    #36
    ron815
    ron815 Active Member
    Ron
    NC
    Tacoma SR5
    Thanks shitroc.
    I had a rattle and tightened the bolt you mentioned. Took care of problem.
  17. Sep 29, 2015 at 4:45 PM
    #37
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Wanted to give this past a bump and add a pic as it has fallen off. It's really the only bolt there. Glad I googled it as I was about to take off the door panel. Such a easy fix. This is an 04 BTW
  18. Sep 30, 2015 at 4:46 PM
    #38
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I was about to take my door a part. Glad I seen this thread, that bolt was really loose. Tighten it up and no rattle!
  19. Aug 18, 2018 at 12:23 PM
    #39
    andnyleswillriot
    andnyleswillriot Well-Known Member
    Nyles
    Breckenridge, CO
    2004 Tacoma TRD 3.4L
    kmc wheels w/duratracs. Bilstein 5100's. Rear firestone airbags. Jayco slide in camper
    Sorry if there is another more current thread about this. I had the rattle like the rest of you, but when I went to inspect that bolt I noticed I don't even have one and it's just a vacant hole. I went to the passenger side and removed the bolt on that side (since I hardly use that window) only to go back to the driver side and notice whatever is inside the panel holding that bolt is no longer there. Does anyone know what's inside the panel holding that bolt in? Obviously the remedy is to take off the panel and replace or find the missing part but was wondering if anyone had this same experience.
    Thanks
  20. Aug 19, 2018 at 2:01 PM
    #40
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    On my 95, the bolt screws into the bottom of the window channel to secure it inline up and down. Just imagine the edge of the window sliding up and down a channel for direction, the channel at the very bottom is what this screw holds. Mine would definitely move to one side or the other with the bolt out, in fact that's how I got to my door lock assembly to remove and lube and clean to keep from breaking the external door handle and yes you have to remove the door panel to access the bottom of the channel to hold it in line with the hole to put the screw back in place if it's shifted out of place.
