Window rubber (mold)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Oct 21, 2012.
  1. Oct 21, 2012 at 12:32 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    Anyone here know what causes these stains? Better yet, how can I clean these off? These are the side window rubber mouldings on my '08 Tacoma DCSB. My wife has an '07 Saturn Outlook & it has similiar stains on the rubber mouldings also.
    Thanks:D
  2. Oct 21, 2012 at 1:31 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    If it worked for your dad then that does no sound crazy to me at all. I will try that.
    Thanks:D
  3. Oct 21, 2012 at 2:01 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OK. Will do.
    Thanks again:D
  4. Oct 21, 2012 at 2:03 PM
    keitha
    keitha Active Member
    keith
    NW FL
    10 Prerunner
    I think this is caused by the sun (just my opionion) but since I added a carport it has stayed off. Try Mr. Clean magic eraser. It worked on mine.
  5. Oct 21, 2012 at 2:04 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Another good idea. I am on vacation this week so I will have time to try these out. Thanks
  6. Oct 12, 2013 at 9:03 AM
    mxdude91
    mxdude91 Member
    Richmond,VA
    2008 Base SR5 4.0L 4x4
    Debadged,Shorten up the front mudflaps 4in,Plastidiped the front emblem,Weathertech Mats/Seatcovers,Tinted front windows
    did you have any luck getting the stains off?
  7. Oct 12, 2013 at 9:51 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I used scotch brite on my window trim with very good results.
    Make sure you tape off the glass and paint or the scotch brite will scratch them.
    Spray on some type of protectant (I used silicone) and your good!
  8. Oct 13, 2013 at 4:49 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Guys,
    I haven't had a chance to do anything but I will REAL SOON & I'll post pics.
    Thanks for the suggestions!
  9. Oct 13, 2013 at 5:00 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I noticed these on mine a couple of months ago. I just figure it is sun, rain, acid rain, pollution etc..
  10. Oct 13, 2013 at 6:58 AM
    mxdude91
    mxdude91 Member
    Richmond,VA
    I'll try that soon thanks for the scotch brite idea
  11. Oct 13, 2013 at 12:26 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    someone should post some before/after pics.
