Window Switch Problem
Discussion in 'Technical Chat' started by Georgeorge, Dec 13, 2009.
  1. Dec 13, 2009 at 10:52 AM
    Georgeorge
    Georgeorge [OP] Member
    Denver Colorado
    1996 Extra Cab 4x4
    Odd problem and stupid decision. The window switch on my '93 MR2 quit working, and was blowing the fuse. The window switch from the MR2 looked the same as the one in my '96 Tacoma. I put the Tacoma window switch in the MR2, and it worked. So, I thought I'd try the MR2 switch in the Tacoma. I fugured the worst thing would be a blown fuse. The windows went down, but wouldn't go up, then I smelled smoke, and it was coming from the window switch. I put the Tacoma switch back in, and I get nothing. I checked the fuse and it was good. Replaced it anyway, but no luck. The Haynes talks about a circuit breaker, but doesn't say where is it. Any ideas are appreciated.
    Thank you
  2. Dec 13, 2009 at 11:57 AM
    Georgeorge
    Denver Colorado
    1996 Extra Cab 4x4
    I got the door panel off, but don't see how to manually raise the window. Anyone know?
    Thank you
  3. Dec 13, 2009 at 12:04 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Welcome to TW!
  4. Dec 13, 2009 at 12:12 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    First off, Welcome to TW.
    You can just bypass the switch and just connect the wires til the window is up. the switch is a on-off-on. so take the "up" wire from the on terminal and ground it to the ground or - wire on the switch. NOTE: Do not leave them connected and this should only be attempted if you have sufficient knowledge of wiring. DO NOT attempt if you feel nervous.
    I can not be held liable if it explodes.
  5. Dec 13, 2009 at 1:09 PM
    Georgeorge
    Denver Colorado
    1996 Extra Cab 4x4
    Thank you for the welcome.
    The switch works in another car, and the fuse is good. I think is has to be electrical in some way. The passenger window doesn't work either. The power locks work fine. I pulled the kick panel, and there is something under it that has DOOR CONTROL on it. Don't know how to tell if it is good or not. Also, there is a knob looking thing on the top of the kick panel that has 2 wires attached to it. Any idea on what it could be?
    The window motor looks like it has a cap on it, maybe something under it to turn to raise the window. I couldn't pry it off, but didn't use much force, afraid of breaking it.
    Thank you,
  6. Dec 13, 2009 at 1:15 PM
    Afwrestler1986
    Johnstown, NY
    Oh Chris........[​IMG].
    Chris should know.
  7. Dec 13, 2009 at 3:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Actually....I dont know much about window switches. If they dont work, I take it out, hit it with a hammer, then buy a new one :eek:
  8. Dec 13, 2009 at 3:54 PM
    Afwrestler1986
    Johnstown, NY
    Or fire right? :D
    You could hook the truck up to 220v and claim insurance somehow?!
  9. Dec 13, 2009 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Havent tried fire yet....I'll remember that for next time :)
  10. Dec 13, 2009 at 4:04 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If you need to get the window up, you can apply direct battery voltage to the window motor's plug. Reverse the polarity if you get it wrong the first time. The circuit breaker is in the switch.
  11. Dec 20, 2009 at 3:15 PM
    Georgeorge
    Denver Colorado
    1996 Extra Cab 4x4
    Thank you all for your input. I got the windows up by the post just before this one. I need to check out the Integration Relay and the Door Lock Control Relay next. It might wait until summer.
