Window trim spotting!!!!
Discussion in 'Detailing' started by ETaco23, May 29, 2010.
  1. May 29, 2010 at 3:18 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    How can I get rid of these damn spots on my window trim pieces?
    I've heard that 303 Protectant can get it clean and protect it, so it doesnt come back. Is this true? If so, Im ganna have to get some!
  2. May 29, 2010 at 3:19 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    303 is great stuff, I highly recommend it!
  3. May 29, 2010 at 3:41 PM
    ETaco23
    Evan
    PNW
    Coo... Will it clean, and get rid of the spotting thats happening to my trim though?
  4. May 29, 2010 at 3:50 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    where can i find this 303? my trims have had that since i got the truck.
  5. May 29, 2010 at 4:07 PM
    ETaco23
    Evan
    PNW
    I just did a search at a couple other forums, and there really isnt much that will get rid of it. You can dress it up a bit, and make it better, but not totally get rid of it. A new piece is about 20 bucks. And I might just do that.
    But the 303 products you can find at any boat supply store or online... Im ganna pic some up just to try and for the rest of my trim and black plastic..:)
  6. May 29, 2010 at 4:21 PM
    ETaco23
    Evan
    PNW
    Does anyone know how to replace this piece? If its hard or not to do? thanks!
  7. May 30, 2010 at 10:17 AM
    ETaco23
    Evan
    PNW
    Bump....
    Anyone know if its an easy job to remove the window trim?
  8. Jun 2, 2010 at 7:01 AM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    I just use some Mother's Black. It will take care of the trim and door handles. But it goes away quickly. I would love to hear about a better option to this issue.
  9. Jun 2, 2010 at 8:24 AM
    ETaco23
    Evan
    PNW
    well I ordered some 303 protectant. Ive heard its great stuff and will help. I will let you know when it comes. I hope it does work so I dont have to replace them.
  10. Jul 15, 2010 at 8:13 PM
    ETaco23
    Evan
    PNW
    The 303 protectant didnt really help. And now Im wanting to replace them. I hope it isnt too hard to do.
    Anyone done this before? its the piece at the bottom of the window, on the outside...
  11. Jul 17, 2010 at 6:09 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Adam's Super VRT. Best stuff hands down. $$$ but worth it.
  12. Jul 17, 2010 at 10:22 AM
    ETaco23
    Evan
    PNW
    Stuff looks pretty awsome! But my trim is damaged from the sun. and pretty much needs to be replaced. But that stuff would be awsome for my Flares and Bumper skirt. Thanks man!
  13. Jul 17, 2010 at 10:34 AM
    scocar
    scocar hypotenoper
    Oh, hey, Ever, here's your thread about this...
    I replaced these right after I bought my 2001 last year.
    They are called "weatherstrip."
    About $32 each from the dealer.
    They come with new clips, so don't worry about breaking the originals (3 each piece). Only one of mine broke. Pretty easy to get off.
    Here are the PNs for the front doors (I have an Xtra cab, so I don't know the PNs for the DC rears).
    Edit: Oh yeah, and what I didn't realize until I started messing with these is that the actual wiper/squeegee portion of the trim that wipes the window was completely bent out and rigid, allowing water to run down into the door! I figured this was probably from the driver resting his arm on it while the window is down. So it is worth checking this on yours, because this could be more than a cosmetic issue for the electrics inside your door...
    I am going to 303 these regularly now. The rubber is super thin on metal trim underneath, so in hot regions, the metal heats up and just cooks the rubber off. I couldn't even tell it was rubber until I got the new ones...
  14. Jul 17, 2010 at 10:35 AM
    scocar
    scocar hypotenoper
    Try West Marine, nationwide chain. There must be several million in FL.
  15. Jul 18, 2010 at 12:37 AM
    ETaco23
    Evan
    PNW
    Thanks a bunch man! It looks fairly easy enough to do. Im about to order them. I went to the dealer today to check on there prices, and they wanted 43 bucks a piece. WOW.... Screw that!
  16. Jul 18, 2010 at 11:20 AM
    ETaco23
    Evan
    PNW
    I found them on toyotapartsbarn.com for 17-18 bucks a piece. way better deal!
  17. Jul 24, 2010 at 12:24 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    I use AutoMagic Bumper Magic.
  18. Feb 22, 2015 at 11:36 AM
    Blake28104
    Blake28104 Active Member
    Blake
    Phenix City Alabama
    09 Prerunner SR5 W/ 3" Toytec Lift
    Areo Turbine Muffler 4" Roll SS Tips at 45 3'' Toytec Lift Toytec Rear 2" AAL's 20" KMC Monsters Nitto Terra Grapplers 33" 275-60-20 6000K Fog 6000K RETROFIT Headlight HIDs BY: Morimoto LED Led Corner Lights LED Tag Lights Flat Tinted Tag Cover Memphis PR1000.1 Amp 2 Rockford Fosgate P3s Scanguage11
    I had the same issues I used tech rubber cleaner . We use it to clean the inside of Commerical tires when doing patch repairs . It cleans any crap off rubber and then hit it with something you like to shine rubber or trim . I've used sos pad soap mr clean with zero success :D
  19. Feb 27, 2015 at 6:24 AM
    GreyFox Ind
    GreyFox Ind Well-Known Member
    Tulsa,Ok
    2014 TRD, Mag Grey
    Toytec coils, and spacers 3". Rear 2" add a leafs. 255x80x17 Cooper ST MAXX
    I searched and can not find anyone that sells that stuff. Do you have a link?
  20. Feb 27, 2015 at 1:43 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Put Zaino z-5 on it.
