Window washer fluid freezing problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MandoTaco203, Feb 3, 2023.
  1. Feb 4, 2023 at 12:39 PM
    #41
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Like...why would they want people's windshields freezing up in the cold? It's so dangerous
  2. Feb 4, 2023 at 1:15 PM
    #42
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    A couple or 3 oz of methyl hydrate mixed into weak stuff works too. Inexpensive if you buy a quart.
  3. Feb 4, 2023 at 1:21 PM
    #43
    Sungod
    Sungod Well-Known Member
    St Augustine
    Flammable? I guess that would help with defrosting. Can you even light a fire at -49c?
    BC Hunter[QUOTED] likes this.
