window water spots
Discussion in 'Detailing' started by l_prettyman, Sep 2, 2010.
  1. Sep 2, 2010 at 12:21 PM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    how do you get rid of water spots on glass?? god they piss me off but no cleaner ive tried works!!
  2. Sep 2, 2010 at 5:26 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
  3. Sep 2, 2010 at 5:36 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i rainx mine alot....and dry em after i wash the truck that keeps mine spotless
  4. Sep 2, 2010 at 5:57 PM
    Basfshr27
    Basfshr27 Well-Known Member
    Marshall
    Gautier, MS
    06 PreRunner SR5 TRD
    A.R.E. Bed cover
    I have found that Sysco Satin Shine is the only thing that has ever worked for me.
  5. Sep 2, 2010 at 7:24 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    where can i buy that from?
  6. Sep 2, 2010 at 7:26 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Mr Clean Magic Eraser damp with vinegar... worked for me when I lived in South Texas and everything was covered in limestone from the local water.
  7. Sep 2, 2010 at 7:27 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    using mothers metal polish lightly worked on my previous truck when nothing else I tried did.
  8. Sep 3, 2010 at 5:24 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    thanks for all the input guys!! im going to the store today to load up on the stuff youve said
  9. Sep 3, 2010 at 5:47 AM
    Jettytaco
    Jettytaco Well-Known Member
    Steel wool from home depot get the finest grade works like a champ and doesnt scratch dont use this on your headlights no plastic scrub with a little bit of water for tougher spot use tougher grade
  10. Sep 3, 2010 at 5:51 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I bought my 2005 Taco about a month ago and the glass on it looked awful. Water spots all over. I tried vinegar, steel wool and metal polish and nothing worked. I found this stuff at a NAPA store and it worked wonders. It's Duragloss Nu-Glass #755. Worked miracles. On the drivers side windows I had to use a drill with a pad on it and several coats, but all my glass looks like new now.
  11. Sep 3, 2010 at 12:08 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    im going to go buy some right now! i just spent like 30 bucks on stuff to try and nothing works. i hope this does
  12. Sep 3, 2010 at 12:26 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    Same issue. These are not just water spots... bought the truck this way... nothing takes them off... i gave up.
  13. Sep 3, 2010 at 12:56 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  14. Sep 3, 2010 at 4:35 PM
    davidsdad
    davidsdad Well-Known Member
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    "Under Cover" Bed cover, 3" Suspension Lift, Sony stereo, 600w amp, Rockford Fosgate 12" sub, wheels, tires, (window tint coming soon).
    Never use steel wool on glass!!!
  15. Sep 3, 2010 at 4:38 PM
    davidsdad
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    Meguiar's Cleaner Wax followed by Meguiar's Quick Detailer is what I use! But, do not put the cleaner wax on the windshield...
    Rubbing Alcohol works as well!!
  16. Sep 3, 2010 at 4:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    chrome polish works to a certain extent.....and i've had good luck with either stoners invisible glass and crumpled newspaper....or a lil vinegar and some crumpled news paper.
  17. Sep 3, 2010 at 4:42 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    What he said. I used an abrasive scratch pad that was not steel wool and it still scratched my front window. Im living with it until I get a rock or crack.
  18. Sep 3, 2010 at 4:43 PM
    silverback
    central CA
    2006 Prerunner SR5
    woops never mind the arrows should have used the quote!
  19. Sep 4, 2010 at 9:18 AM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    wax ur windows
  20. Sep 4, 2010 at 10:06 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    wax them??
