Window Whoas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4jeep, Nov 9, 2011.
  1. Nov 9, 2011 at 5:23 PM
    4x4jeep
    4x4jeep [OP] Well-Known Member
    Kyle
    Destin FL.
    My passenger side window won't roll up? Any ideas? Already checked fuses. Its an 06 I wouldn't expect the motor to go out already?? Thanks
  2. Nov 9, 2011 at 5:24 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It's "woes". Free bump for you.
  3. Nov 9, 2011 at 6:00 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    your window lock isn't on is it ????
  4. Nov 9, 2011 at 6:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Checked the window lock?? Have you disconnected the battery or anything??
  5. Nov 10, 2011 at 2:30 AM
    4x4jeep
    Kyle
    Destin FL.
    No window lock isn't on and haven't disconnected battery. Everything else works fine
  6. Nov 10, 2011 at 2:37 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Pull off the door trim and inspect the motor. Sometimes they seize.
  7. Nov 10, 2011 at 3:04 AM
    maxboi
    maxboi MAXBOI
    Brian
    SODA CITY
    2011 White D'Cab OR 4wd
    76 FJ horns, Weathertechs, Backup Camera anytime switch, Fogs anytime, Clamp & Washer tailgate, Diff Breather,
    1) have someone hold the switch in the direction you want it to travel
    2) wiggle/jiggle the wire harness in the drivers foor jamb, you could have a failed wire in the door jamb area.
    3) do the same on the failed door
    4) the actual switch may be in need of cleaning. If you are careful they can be opened and serviced.
  8. Nov 10, 2011 at 7:25 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure the window relay isn't faulty by swapping with a known good one. If good, check that the window motor is getting power at its connector. If powered, replace the motor. Clean and lube the rails and mechanism before closing up.
  9. Nov 10, 2011 at 7:35 AM
    MTLTaco
    MTLTaco Well-Known Member
    Montreal
    09 Double Cab TRD
    I had the same issue twice. My passenger was not able to roll the windown back but I could do it from the driver's door main swith. First time the passenger window switch was changed under warrenty. A few months later same problem so I they changed the main swith on the driver's door and now no more problem.
  10. Nov 10, 2011 at 8:46 AM
    4x4jeep
    Kyle
    Destin FL.
    It was the window lock button :anonymous:
  11. Nov 10, 2011 at 8:52 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Easy fix:yay:
  12. Nov 10, 2011 at 6:12 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    We've all done it.........
    Don't hide your head.
    glad it was something simple...
