Windows not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrGreenJeans, Mar 23, 2024.
  1. Mar 23, 2024 at 5:12 AM
    MrGreenJeans
    MrGreenJeans [OP] Member
    Tacoma TRD Off Road
    Was installing stereo equipment in my 2023 yesterday and now only front passenger power window works. Any idea of how to troubleshoot?
  2. Mar 23, 2024 at 5:27 AM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    check the window lock button
  3. Mar 23, 2024 at 7:06 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did you disconnect battery? If so, you have to go to each door and reset window switch. Window down,, hold widow up hold switch.
    Chew likes this.
  4. Mar 23, 2024 at 10:13 AM
    YotaHead858
    YotaHead858 Well-Known Member
    San Diego, CA
    2023 TRD OR
    King Shocks Camburg UCA's
    Did you touch any of the rear door speakers? If so, maybe rear door window switches are unplugged?
    kahanabob likes this.
  5. Mar 23, 2024 at 10:29 AM
    MrGreenJeans
    Tacoma TRD Off Road
    I removed an rca cable that was going from under drivers seat to head unit. I rerouted it so it ran from under drivers seat down left side of truck to behind back seat. BSM now has error when turned on and drivers along with both rear windows are not working.
    stereo now sounds amazing though
  6. Mar 24, 2024 at 10:43 AM
    YotaHead858
    San Diego, CA
    2023 TRD OR
    might sound obvious but have you checked fuses and ensure that the connectors to to window switch on driver door is plugged in correctly?
  7. Mar 24, 2024 at 12:08 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Why is it that anyone who does something as simple as changing a light bulb in these trucks
    finds some other electrical gremlin pop up.
    Reminds me of the question:
    How many optometrists does it take to change a light bulb...?
    One?.....
    or Two?
    One?....
    or Two?
    KactusJack likes this.
