Windsheild Wiper Fluid Empty light on even though it's full???
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Nov 27, 2011.
  1. Nov 27, 2011 at 8:00 PM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    My windsheild wiper fluid ran out and i left it empty for a few weeks. I filled it yesterday and i noticed the light it still on. What gives? This isn't the first time i've ran it dry and refilled it but it's the first time the light has stayed on. Any thoughts?
  2. Nov 27, 2011 at 8:02 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    You have a light for that? Must be a 1st gen thing. Damn!
  3. Nov 27, 2011 at 8:17 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I was about to say that, figuring it was a 2nd Gen thing! :eek:
    I guess I've never run mine low enough to see it...
  4. Nov 27, 2011 at 8:19 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    switch could come lose or can be stuck in closed position
  5. Nov 27, 2011 at 8:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    Toyota really cheaped out on these second gens!:rolleyes:
    Edit: I guess I should be productive here: I did have a washer sensor (float) go bad on a Dakota that my dad owned. We used to fill the reservoir with water and then add a little dish soap instead of buying washer fluid. I'm pretty sure that's what killed it. Never bothered to fix it. Unplugged the sensor, the light went off, washer fluid got topped off while checking oil from then on.
  6. Nov 27, 2011 at 8:36 PM
    SCFirefighter
    Stephan
    Cary, NC
    What kind of sensor is it? Is it a floater like you have in the toilet? If so perhaps the ball (that gives the buoyancy) got disconnected or the arm holding the ball just got stuck in the down position, signaling low level.
    ETA: If it is a floater see if you can agitate it (move it) and see if it bounces back up.
  7. Nov 27, 2011 at 8:53 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    I went to replace my tank on my 95 ordered a new one and no SHIT it had a hole at the bottom of it for a sensor. Had to buy the sensor next to fill the hole. MY truck doesnt have that option but it will soon when i get it wired ( see note below).
    THo the dash on mine doesnt have a spot for low washer fluid. crap. bummer.
    Nor does the light for low fuel work either never has since it was new. i checked the bulb its good. i dont think it was wired for it.
  8. Nov 30, 2011 at 5:31 AM
    x2468
    Vermont
    Well I've done a few bumpy offroad drives so far and that hasn't agitated it away. I'm starting to worry it might be an electrical thing since ad of yesterday, when I start my truck the brake light on the dash is on (even though I don't use the parking brake and it isn't on). The light stays on for a few minutes then flashes on and off like the fuel empty light when its on the fence about how much fuel I have until it finally goes away. Not sure if this is related or what.... might make a new thread but I'm going to search soon.
    Before putting in the new rain-x fluid I bought I found a 6th of a jug from the summer (I believe) that I figured I'd throw in first. Big mistake because as I started to pour it I noticed this black Fleming like substance that at coagulated in the fluid. Only a few cups got in before I noticed but it has me wondering. I removed that filter like a dummy so the Flemy substance went in.
  9. Nov 30, 2011 at 6:02 AM
    SCFirefighter
    Stephan
    Cary, NC
    You can add a $0.99 bottle of isopropyl alcohol (rubbing alcohol) into the window washer container. That might help dissolve the gunk. (it also works great as a de-icer)
  10. Nov 30, 2011 at 7:09 AM
    x2468
    Vermont
    I was just thinking about asking that as I was driving home. I've used a combo if alcohol and salt to clean out other things with great success.
