Windsheild wiper spray nozzle issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Mar 16, 2017.
  1. Mar 16, 2017 at 8:09 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    Has anyone come across this problem where one of their spray nozzles barely sprays anything onto the windshield? I have tried unclogging it… I checked all the water lines… And can't seem to find the problem… Does anyone have a part number for the nozzle itself?
  2. Mar 16, 2017 at 8:11 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    85381-04010
    STEVEO13016[OP] likes this.
  3. Mar 16, 2017 at 8:43 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    What have you done to unclog it? Sticking a pin in and moving the eyeball around usually works. Disconnect the hose at the nozzle and hit the spray button to flush out any debris.
    Try blowing air in the out. If you don't have an air hose at home you can connect a valve stem to the air hose at the gas station, then use that to blow.
  4. Mar 16, 2017 at 11:13 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I got these washer nozzles after dealing with the same issue every month They have 3 holes and are from a rav4. They fit exactly the same as stock.
    85381-42070
  5. Mar 16, 2017 at 11:28 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Do these give a better spray pattern overall? Mine aren't clogged, but are pretty underwhelming
  6. Mar 16, 2017 at 11:29 AM
    nzbrock
    Noah
    San Marcos, TX
    They are pretty much the same straight stream, you just get 3 streams instead of 2.
    lukester78[QUOTED] likes this.
  7. Mar 16, 2017 at 1:14 PM
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
    my 04 tacoma has terrible washer spouts. one goes so powerful and the other one is weak AF
  8. Mar 16, 2017 at 3:43 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
