Windshield Condensation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Dec 9, 2010.
  1. Dec 9, 2010 at 10:04 PM
    OffroadToy
    OffroadToy [OP] This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Lately I've noticed alot of moisture forming on the inside of the windshield when the truck sits in the driveway overnight... anyone know a way to avoid it from happening like a certain climate control setting?
  2. Dec 9, 2010 at 10:30 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    It doesn't prevent it from forming , but I go full fan , full heat , in the defrost setting with Max AC on when starting , seems to clear it the quickest .
  3. Dec 9, 2010 at 10:31 PM
    cactuscorn
    cactuscorn Another FNG
    El Paso, TX
    2016 BBR TRD OR AT DCLB w/JBL
    OEM bedmat, Weather Tech mats, JDM ASTAR 800 lumen LED reverse bulbs, blue LED dome light and every cubbyhole filled with crap.
    can ya set it to arizona? when i lived in the midwest, the winters could make this a real pain in the ass. i played with coatings inside and out, windows up, windows cracked, blah blah blah. the only way i got it to stay dry is when i parked inside and that didnt happen often. i just pre-heated the car before i went to work. the defrogger was my pal.
  4. Dec 10, 2010 at 11:40 AM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    lol i've noticed the same thing this year. I dont remember it happening much last year.
    When we had the snow/freezing temps here in Seattle. I had frost forming on the INSIDE of the windshield. LOL
    First for me in all my vehicles.
  5. Dec 10, 2010 at 11:54 AM
    OffroadToy
    4X4 Offroad
    Same here...I don't remember this happening to this extent in my other vehical's either. I thought maybe having the climate control set to the vents at the bottom of the windshield was the culprit and left the knob adjusted to the vents on the floor...didn't seem to make a difference. WTF? :confused:
  6. Dec 10, 2010 at 5:23 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    happens to mine too.
  7. Dec 10, 2010 at 5:40 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Well the moisture has to get in the car first before it can condense on the windows. This CAN be an indication of a heater core leaking however I doubt that is your problem. Water soaked into your carpet floor mats (from wet shoes) can also have this effect.
    However in the end there is moisture in the air as well and you cant really help that while the truck is parked. My advice is to clean your windows (inside) often. I find with windows that are good and clean it defrosts much faster and seems to fog up much less.
  8. Dec 10, 2010 at 5:44 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    In all these years, I've never found a solution. If there's moisture in the air, you end up running the defroster or floor defrost settings which both run the AC compressor. That alone will create condensation that has to drain out of the cab. And then there's moisture in there because it doesn't all drain out. This forces you to run the defrost setting in the morning. Vicious cycle! You can double check that your drain hose isn't plugged (and isn't going uphill as many have found before traveling out thru the firewall). And you can try turning the defrost off and running the fan for awhile before parking for the night. But doing that usually fogs them up before you even park (even with the windows cracked). So only solution I've ever found is to continue to use the defrost or floor/defrost setting until the air is dry enough to switch it to floor and not run the compressor.
  9. Dec 10, 2010 at 5:46 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    It may be due to the fact that these newer vehicles
    are sealed better and that doesnt allow air movement
    like vehicles of the past. The truck holds the moisture.
    my new house does the same thing
    every morning im wiping down wet windows.
    when i asked about what i could do about it
    he stated leave the windows open alittle.
  10. Dec 10, 2010 at 7:37 PM
    cactuscorn
    El Paso, TX
    these guys all bring up good points. also, normally humidity goes up in the winter so yer pretty much screwed as soon as ya crack a door open much past november
  11. Dec 10, 2010 at 7:41 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Um I think you have that backwards...typically it is less humid in the winter due to the cold dry air.
  12. Dec 10, 2010 at 8:34 PM
    cactuscorn
    El Paso, TX
    try a winter or 7 in iowa. not typical? perhaps i was wrong there
  13. Dec 10, 2010 at 9:56 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    I would make sure I didn't have wet carpet somewhere, they can hold a lot of moisture if they get wet, especially if underneath a plastic floor mat.
  14. Dec 10, 2010 at 10:40 PM
    OZ-T
    Peter North
    British Columbia
    Off topic , but you should not have that much moisture inside a new house unless there is inadequate air exchange , or you don't run your kitchen range hood and bath fans for long enough .
  15. Dec 11, 2010 at 6:49 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That's happening because moisture is building up in the cab. I'd suspect you have the recirculate button turned on, normally?
    Don't do that if you do.
  16. Dec 11, 2010 at 7:29 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Sorry off topic again, or the humidifier is set too high. To the OP I have not had this problem yet, but my wifes Equinox gets pretty bad in the winter. I have checked for leaks everywhere, and think its the mats. She doesn't get the snow off her feet or anything getting in and it just sits on the mats. Being cold it just stays there and takes a long time to dry.
  17. Dec 11, 2010 at 7:54 AM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    Just turn on the blower fan and wait a second....happens all the time no big deal...also I run my a/c all the time. Whats all the fuss!!
  18. Dec 11, 2010 at 9:30 AM
    OffroadToy
    4X4 Offroad
    Great suggestions! I usually have some standing water on the WeatherTech floor mats so that could what's causing it. I'll check out a few of your other ideas and report back...Thanks!!:thumbsup:
  19. Dec 11, 2010 at 9:34 AM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    My son had that happening a lot. I told him to get rid of the soaking wet floor mats and ALWAYS use outside air when driving to keep things dry inside.
    Problem solved.
