Windshield fluid sprayer nozzels
Discussion in '1st Gen. Tacomas (1995-2004)' started by DestroyerLite, Dec 5, 2014.
  1. Dec 5, 2014 at 6:14 AM
    DestroyerLite
    DestroyerLite [OP] Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    I am not even sure that is what they are officially called but from some searching I done on this forum it seems so. Mine are basically stock and and they just spray a dual stream per nozzle on the windshield. Not that is bad it does just fine but my 2013 Jetta has a nice thing where it soaks the whole windshield and not just two spots.
    Does anyone know if I could buy some new nozzles that do this and just install them and if so has anyone done anything like this that can point me in the right direction?
    Thanks,
    --Dan
  2. Dec 5, 2014 at 7:01 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I think you have touched on something that has never been discussed on here,,but I could be wrong.
    2013 Jetta nozzles will work?
  3. Dec 5, 2014 at 7:29 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yep, im in, the stock ones suck so does anyone have info on good replacements? I don't want to have to "make something work" so I want a simple pop in replacement if there is one.
    wonder if the new Tacoma ones are any better?
  4. Dec 5, 2014 at 9:10 AM
    Madjik_Man
    Colorado Front Range
    There is a thread here where someone took the sprayers off a Lexus(?) and they were a direct plug and play on the Tacoma.
    Instead of the dual stream the pattern is now a fan spray.
  5. Dec 5, 2014 at 9:26 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    I agree... I hate the two stream bs... especially with ice
    gonna try search'n
  6. Dec 5, 2014 at 9:36 AM
    keakar
    karl
    louisiana
  7. Dec 5, 2014 at 9:42 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
  8. Dec 5, 2014 at 9:52 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    MOST TOYOTAS ARE THE SAME, WHEN BUILDING My sons 98 taco sprayers were broken off,called dealer they wanted 20something each,f that went to junkyard,started looking at other toyotas,got a set out of first corolla i came to,guy didnt even charge me.
  9. Dec 5, 2014 at 9:54 AM
    DestroyerLite
    DFW
  10. Dec 5, 2014 at 10:07 AM
    keakar
    karl
    louisiana
    someone in that thread mentioned second gens had a fan pattern spray but nothing more was said about it, can anyone confirm if it is this true and would they fit first gens?
    guess its better I should go ask this in second gen forum :p
    I don't want to have to "rig" or glue something on there, I want a snap in replacement for it
    EDIT: here is that post in 2nd gen forum: http://www.tacomaworld.com/forum/2n...id-spray-pattern-do-you-have.html#post9532169
    maybe between here and there someone will have the perfect solution
  11. Dec 5, 2014 at 11:18 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    well maybe I'll try it myself... gotta buy some OEM parts when I get back from DC next week... might check to see how different and expensive the parts are...
    besides, I want to hook up something for spraying off my headlights so I'll just move the others there...
  12. Dec 5, 2014 at 12:27 PM
    keakar
    karl
    louisiana
    I THINK I FOUND IT!
    ok, nothing has been tested yet but my moms 2003 camry LE has the fan spray nozzles on it and while I cant swear they are a direct snap it fit (her hood insulation is in the way so I cant pop them out easily and I cant risk breaking them just to see) but they look and feel identical shape snap to the ones on my 99 tacoma so I think that would be the ones to buy or get.
    ebay has one here: http://www.ebay.com/itm/1-Windshield-Washer-Nozzle-Fit-Toyota-Corolla-Echo-MR2-Tacoma-Celica-Camry/191418764707?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27538%26meid%3D3f51692df51e4989a5968c0e3037c11a%26pid%3D100005%26prg%3D11353%26rk%3D2%26rkt%3D6%26sd%3D111501396859&rt=nc
  13. Dec 5, 2014 at 12:39 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    ok... I will check when I get back... thanks!
  14. Dec 5, 2014 at 1:26 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
  15. Dec 5, 2014 at 7:12 PM
    CR, WA
    stock
    A high lip bug shield will diffuse the two barrel nozzles,,splatters it all over when your at certain speeds. Makes a Typhoon on the hood.
    I have one,,gathering dust in the rafters,,lol.
  16. Dec 8, 2014 at 10:30 AM
    keakar
    karl
    louisiana
    anything to report yet?
    ok, upon further review it looks like these "may" not work on our trucks because the 90 goes forward instead of to the side and "could" be a clearance issue getting the nipple and hose to fit inside there where the hood brace encloses it.
    for this reason im thinking something like this would be a better replacement and whats needed for our trucks: http://www.ebay.com/itm/281242036327?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    unless im mistaken "most" of these washer nozzles are using a standard set of 2 or 3 pattern shapes with some having a thick snap opening gap style for double wall hoods and some are thin gapped flush like style such as with our trucks so if you find the right pattern and snap thickness gap, the car manufacturer brand shouldn't matter.
    im scared to waste $ to buy them and find out they don't work but if any of you don't mind taking the gamble for the rest of us, it would be of great help to many and I would say thank you thank you thank you.
  17. Dec 8, 2014 at 12:36 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    No I'm on my way (currently stuck in Chicago) to DC. Won't be back till the 15th
  18. Dec 8, 2014 at 12:37 PM
    DestroyerLite
    DFW
    Don't buy the crud from Autozone... I just wasted $10 and they lasted two days and the spray pattern was pretty awful. I am going to see if I can find some OEM that will fit.
    --Dan
  19. Dec 8, 2014 at 12:50 PM
    keakar
    karl
    louisiana
    that's good to know, thanks
    if your looking OEM I heard there is a 3 jet version, I think from rav4 you might want to look for.
    in my short search I found the biggest hurdle is the hose bib direction needs to be straight down or to the side. many go straight forward which as I mentioned above could be and I think is going to be a clearance issue with them.
    also I find on my 99 I have NO adjustment to these at all, the needle will bend but the direction never changes at all in up or down direction or even side to side, its like its fixed in one spot only. I don't know if that's because the older ones are not designed to move or if its just stuck from never being moved in 15 years but weather I go spray or jet I need to get ones that can be adjusted because mine cant.
  20. Dec 8, 2014 at 2:24 PM
    Darryle
    Darryle
    Weatherford, Texas
    Look at the link I posted above, it references the Rav4 3 nozzle sprayer
