Windshield fogging up all the time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bennett, Aug 26, 2012.
  1. Aug 30, 2018 at 5:53 AM
    #61
    sgtmav
    sgtmav New Member
    2014 Tacoma LB
    And yes super annoying.
    LMFAO!!
  2. Aug 30, 2018 at 10:19 AM
    #62
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    This happend to me in my 2000 Taco. It was the heater core.
    sgtmav likes this.
  3. Aug 30, 2018 at 10:25 AM
    #63
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    How exactly would someone check it for clogging?
  4. Aug 30, 2018 at 3:00 PM
    #64
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    As long as you see water dripping under the truck after A/C use, then I'd say you're good. Otherwise you can see the drain on the firewall passenger side.
    I married my tacoma likes this.
  5. Aug 31, 2018 at 1:22 AM
    #65
    Black Stallion
    Black Stallion over-worked & under-paid
    Paul
    Western Washington
    2015 MGM TRD SPORT Access Cab 4x4
    No mechanical mods. Minor convience and useability tweaks.
    Replace the cabin air filter.
  6. Aug 31, 2018 at 5:41 AM
    #66
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    All it is where conditioned air is leaking around the defrost flap and blowing small amounts onto the windshield. (Same as if you were to point your side vents on the windows). Only thing I have done to fix it was roll up a small black towel and lay it over the defrost vent. No more condensation.
  7. Aug 31, 2018 at 5:48 AM
    #67
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    One thing you can also do to help combat this is to take a dry microfiber cloth (or two) and act like you're cleaning the glass with windex or something. Just rub the glass in circles with the dry cloth. Make sure not to turn the cloth over and expose the side with the oils from your skin on it. This will get rid of the "haze" on your windshield but not the fog caused by humidity. What happens is there are chemicals that get expelled from the interior plastics and they settle on the inside of the windows. The microfiber cloth helps pull them off and does a surprisingly good job.
  8. Aug 31, 2018 at 6:12 AM
    #68
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Your windshield isn't fogging up. You have condensation on the outside if you're clearing it with the wipers. This is normal and happens to me quite often regardless of the vehicle I'm driving. The outside air is hotter with near 90% humidity here in GA. The inside of your truck is much cooler with much lower humidity. People who live in areas with low humidity can't relate.
    Don't use the defrost setting, it is blowing cold air directly on the windshield and making it worse. Set the AC to blow out from the bottom or at least adjust the vents in the dash so they don't blow on the windows. Adjusting the temperature so it is not quite as cold also helps.
    HoulaHauler likes this.
  9. Aug 31, 2018 at 6:34 AM
    #69
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    is all that's needed unless the fog is on the inside from my favorite mod. ;)
  10. Aug 31, 2018 at 6:48 AM
    #70
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    As a Georgian, I concur. My 2013 does the same thing. A/C drains great, cabin air filter is new. It's just the nature of the beast in the south.
  11. Aug 31, 2018 at 7:52 AM
    #71
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    In my experience it is condensation on the outside of the windshield at the bottom. Air conditioning causes it and wipers will clear it. Redirecting a/c as mentioned helps. This is all barring other rarer mechanical problems. It is annoying though. I have had it on other vehicles too.
